Just wanted to know if removing lights are as simple as it should be or if i have to remove the front bar in the process, and also i am changing from the aus lights to the xenon lights just want to know if it a simple cut and splice or far more complicated process.
Any help would be great
Thanks
Josh
https://www.sau.com.au/forums/topic/344485-help-removing-headlights/
no idea on the front bar/light removal. would be interested to know tho!
as for straight swap, do you have the ballasts for the xenon globes? should just have to plug the loom into those.
its easy to remove the lights, also easy to put in Xenon kit. if you want specific pics i can get them to you tomorrow.
but the basics are: Right side, remove battery so you can get to the bolts better, then you can see it is bolted on at the back by 2 bolts i think, one pretty low and the other one middle height, (both are nuts)
also your headlights are a 3 piece setup. your main headlight connects to a support connector which then connects to your high beams.
the support connector is connected on the top and side of your headlight and the back of the radiator support, undo just your headlight (top and side of your headlight)
then you can pull out your headlight and the wires. thats your right side done
now left light, same thing basically but to get it undone, you have to basically undo the 2 bolts on the top of your radiator bar holding in the black can, there is a headlight screw right behind it.
also there is another screw bottom right of the headlight aswell (if your standing in front of it). then just follow the other steps like the other headlight. remove air box if you want more space.
to put in the xenon kit, its pretty easy. but for that i gotta know if its the original xenon kit thats attatched to the lights or if its an after market one
cheers
Jean
p.s you dont need to remove of front bar
Edited by Bronx
Series 1 or 2?
I managed to get one head light out but really should have taken the front bar off (fair bit of bending of plastic stuff lol), it was such a mission I cracked the shits and gave up (after putting the headlight back in).
Edited by bubba
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
