FI are still yet to launch their new car thats why it looks the sam, same for Virgin and Mclaren, although I find it weird that Virgin have a fully connected shark fin in that pic even though they never had one last year and they are banned for 2011.
Red bull seem to have a shark fin type thing.. however it doesnt extend all the way back, more cheekyness from adrian newy?
I read somewhere that the Red Bull shark fin extends to the absolute maximum that the regs will allow, leaving only the minimal gap required, surprising to see that they are the only ones to really to do it yet.
thanks for the pics. wow. some of the cars are really radically changed compared to last year. which I guess is to be expected given the regs. look at the front wings. my god could they get any more complex? not much chop when you bang wheels with kobayashi and loose half ya 'bits' on the first lap though...
These were a couple I used last year:
http://www.vipstand.me/
http://www.tvkorner.com/
Good for watching practices and quali's and having on the laptop for when channel one goes to commercial, but neither were tv quality picture.
The new Pirellis dont that THAT bad on the McLaren, sure white or red would suit better but its still not exactly an ugly look
They just have large signage on the launch & test cars so everyone knows who the tyres belong to. By the time they start racing properly the tyres will be covered in black so you wont even notice the branding. Hell half the time it was near on impossible to pick who was on what tyre anyway.
Anyway McLarens look better in orange so who really cares.
Edited by djr81
Check out the 3D model of the MP4-26 on the McLaren racing site; Serious looking exhaust blown wing setup. Looks to be supplemented by some scoopage near the airbox inlet.
Now let's see the relative PACE!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
