F1 to run cockpit covers...?
http://www.formula1....11/7/12314.html
HD video of the test
http://vimeo.com/26098946
They should look more towards the titanium outer cockpit shell that the Tiger Attack Helicopters have, I guess this would reduce the chance of vaginal bruising by 43.27%
and reduce instances of sand contaminants by a large magnitude.
Unrelated to the above pic, was just saying,hoping for webber to do well means constant disappointment. And one hd uses every gp as just random ad time, placed at interesting parts of the race. Every weekend we just hope for better-than-awful coverage and we're usually disappointed
Whats amazing about their coverage is that no other country i've been to and watched a GP has played so many ads
In germany there were maybe 4(?) when the canadian GP was on last year. It was orgasmic. Fair enough they were speaking german and you heard the word 'vettel' upwards of about 7894 times, but the action was great!
As bad as all the ad's are, it's still 1000% better then when 9 did the coverage. Delayed and edited races were normal back then, with no quali.
Stop your pharken whining all of you.
We get to watch it on Win. In glorious fuzzy analogue, 4:3 ratio so you cant see the drivers names down the left hand side of the screen. Broadcasts usually start at about 2.30 AM on a Monday. They dont show qualifying at all.
Pharken win. :down:
when i missed then end of the canada gp i downloaded the fox coverage and listening to them mispronounce every driver's name and going on with shit they cleraly dont understand :domokun:
it was worse then listening to julia gillard. :down:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
