doesn't matter, if Webber got pole he'd just clutch slip and be 8th at the first corner so it's probably better he start back there to keep an eye on the front runners straight up.
did anyone notice Vet's head is about half the size width wise as button/hamilton? he still has time to put on the kg I guess.
from his own mouth
pf1
Daniel Ricciardo: "It feels really nice not being on the back of the grid and finishing ahead of Tonio, which is a small target I had set myself, so I'm happy to have achieved that. But I don't want to stop there, I want to do it constantly and progress in one way or another. It's been a tough weekend having suffered some mechanical problems in yesterday's practice sessions, so we didn't get to run as much as we would have liked today. I was aware that I had to give everything I could in this qualifying session and it's really satisfying to have done a good job. Now we have to wait and see how tomorrow goes but I think we should have a good set-up because we didn't go completely aggressive in qualifying."
new boy dun good.
Can't wait for the race, every time hamilton lines up next to vettel, vettel must be wetting himself
any time anyone is within 100m of hamo on the track they are probably wetting themselves wondering when he will take them out, LOL
No offence to ricci and the HRT crew but once you hit 107% quali time why not bring it in at that point to save the tyres? They're not going to get much better except between teammates and they could have better race pace which I would think is more important....from a team point of view.
pretty sure they will still have pretty much a full range of new tyres. they only did 1 qualifying session after all, so they would've only used 2 sets of tyres at most.
i reakon it was a team thing to help get vettel to win the championship ASAP. once that's done and dusted then i think they might let mark have a chance at winning to make sure they can cement his place at number 2 in the championship (forever number 2, LOL)
just watched vettels pole lap on tv. as the dopes (presenters) mentioned, he spends a lot of time on the limiter on the first straight, and a bit on the back straight.
Didi u see the side by side laps compared with lewis? they are neck and neck and sometimes lewis in front but the second chicane is where vettel gets it
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
