HRT were forced to change Ricciardo's gearbox, earning him a mandatory five grid-slot penalty. However, his average qualifying position is P23, which means he will most likely just drop to the back of the grid.
mark on Vettel helping him.
"There has been a lot of talk from the team but nothing from me. I don't want any positions off Sebastian for the remainder of the year."
Indian fans run riot as Metallica axe gig
Angry fans smashed equipment and hurled bottles in chaotic scenes after heavy metal group Metallica cancelled their first ever Indian gig at the last minute, reports said Saturday.
Thousands of fans had already turned up at Friday's concert, timed to coincide with this weekend's Formula One Grand Prix, but were enraged when it was axed for safety reasons.
Newspaper pictures showed piles of shattered equipment and the Times of India said one man broke his leg when he was pushed down a stairwell in a stampede.
"Many others were also injured in the melee," Shouvik Roy, 41, was quoted as saying, adding that some youths were also taken to hospital. "There were no marshals to guide people and few cops to help."
Metallica said the concert in Gurgaon, near New Delhi, was initially postponed to Saturday because of damage to a security barrier, but organisers were then unable to secure a second permit.
"We are deeply disappointed with this news as we were looking forward to our first experience in India as much as you guys were," they said in a statement late on Friday.
The Times, which pictured youths in Metallica T-shirts shouting and showing their middle fingers, said fans tore down sound systems, barriers and hoardings, and threw bottles at the stage and LED display screens.
"I'm glad my sons got out from the #Metallica madness unscathed. Why can't we organise an event without drama????" tweeted Kashmir chief minister Omar Abdullah.
The incident comes after Canadian rocker Bryan Adams called off a concert this year when police refused to give clearance. Flamboyant pop star Lady Gaga is due to perform after the Indian Grand Prix on Sunday.
well the weekend has started well.... lets hope the race is just as eventful.
Edited by tweety bird
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
