  On 31/07/2011 at 1:18 PM, skins said:
Is that water vapour coming of the rear wing of the vodaphone cars when they come done the back straight? It doesn't seem to be there on any of the other cars
Most of the cars are doing it, and yes, it's water vapour
  On 31/07/2011 at 1:18 PM, mad082 said:
hamo did a good job at trying to hit the force india then. wouldn't be suprised if he gets into shit after that (possibly post race)
  On 31/07/2011 at 1:18 PM, sav man said:
What's the chances of Hamilton getting a drive through for the flick spin.
how good are we? LOL
it's caused by a low pressure area allowing the moisture to condense a bit. you see it quite a bit, just on wet races where it's a bit darker you notice it more. you also see it from jet fighters when they bank, as well as sometimes in the redbull air races.
I figured they'd wait until post-race for Hamilton, but not surprised that he got done.
Pitting for inters looks like a strategic blunder ... it's so hard to call that though. Get it right and you're a hero, get it wrong and you throw away 30 seconds.
  On 31/07/2011 at 1:32 PM, gts-4 dreamer said:
How many promises to go to the end without more adds have they broken?
well at the ad break before the last one they said "1 more after this one", so they will only have broken the promise if they go to another ad break from now on.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
