Interesting, good to see an official explanation on it. Surprised it wasn't kers related
me to, i thought it was a battery fire/ explosion (having seen them explode it the past)
i didn't know that they have air power valves, does anybody know if they are air powered open and closed or if they use a cam to open the valves and then the air to close the valves?
Helmut Marko has revealed that Daniel Ricciardo will most "likely" replace Mark Webber at Red Bull - but it won't be next season.
With Webber on the verge of signing a new one-year contract with Red Bull Racing, Ricciardo, who made his F1 debut with HRT at the British GP, is set for another season with a lower ranked team.
However, the 22-year-old can look forward to a bright future with a Championship-winning outfit as Marko says he'll most likely take Webber's race-seat when the older of the two Aussies calls it quits.
"Mark Webber will stay with us for another year, and then he will decide what to do in his career," crash.net quoted Marko as having told the Italian media.
"Red Bull will decide who takes his place, although it is likely it will be Ricciardo."
yeah buddy
That's what alonso thought of hamilton back in '07, we'll just have to hope by then ricciardo can bring it to vettel. If he's aggressive, and he's a young aussie male so he probably is, he might be enough to push vettel out of his comfort zone.
hards are goooone ferrari must be happy
Having announced that they won't use the hard compounds in the next three races, Pirelli have now confirmed that they are dropping the tyre completely.
Pirelli announced after the Hungarian GP the compounds for the next three races with the medium and soft compounds being used at Spa and Monza and the soft and super softs at Singapore.
The Italian tyre manufacturer's decision raised some eyebrows as it is well known that Ferrari especially struggle to get heat into the hard tyres.
Pirelli, though, were quick to deny favouring the Italian stable but may have to issue another rebuttal after Paul Hembrey confirmed that the hard compound would not be used again this season.
"I don't think we'll see the hard compound again," Pirelli's motorsport boss told Autosport.
"I think it's probably too hard and that the medium is proving sufficiently robust for the aggressive circuits we've still got to come. So don't think we'll be going the hard route."
He added: "Probably next season the medium will become the hard. We'll probably slot something in between the current softs and mediums - We want to keep about one second between each.
"The super soft and soft gap is about right to be honest, because you've got a 1s speed advantage but you've got a clear degradation and limitation on use.
"If we could replicate that now with a new medium and a new hard then I think we'll be well placed."
pf1
Hey guys meed some help
Missus is getting me a 4 corner pass for melb 2012,
But the brabham stand (the most exxy package) is where id b sunday, but it doesnt look to be a fantastic spot?
I
Was in piquet stand last yr, (crn 4) and was nice and slow so u could see them.
Where are all u guys sitting and have sat b4? Any tips?
And where did u get ur pit walks from??
brabham is a good stand. inside of T1 so you're almost guaranteed a first lap first corner acco. plus that's usually a good passing spot up the inside of T1, hold it on the outside through T2 then hold that line for the inside of T3 and job done.
yeah the cars come in hot down the straight but T1/T2 is a fairly slow chicane type of thing. you will see plenty.
sounds like a plan!
just fox tickets yeh? ill harass them for the pit walk. hopfully ill get in! did u get an extra ticket for that or anything?? and is it on sunday the pit walk?
thanx guys :)
saw shuey have a fairly quick gravel slide last yr in piquet. good times! should organise to catch up as a group and go for a sniff around the place, plenty to 'see'
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
