No idea to be honest.
Well I'm pretty much the opposite; I've never really bothered with 'career' mode in F1 2010, and just do time trials on tracks that interest me instead.
My best time at Spa (using the MP4-25) is 1:44.815
That's right mahfuggaz- I'm faster than Kimi Raikönnen... on PS3.
Well if there going to give Cruise a go they should really let Rowan Atkinson have a go, kicked his ass on the top gear track. lol
also i think that rossi didn't drive the F1 car because of a sponsorship dispute with Ferrari/Shell and whoever he was with at the time.
Edited by stR33ter
He did in 2008, was 2 tenths down on Raikkonnen's record at Catalunya
http://www.formula1.com/news/headlines/2010/1/10355.html
I'll see what kind of time I can get next time I play.
Should have Internet again soon too so might have to get some online action going
Yeah, he must have spent a lot of money buying heidfelds seat.
who keeps giving this guy chances anyway, if he was anything, with the name he's got and the money behind him, he would be in F1 by now.
Doubt whether having Kubica would make any difference to how the Renault team are performing, Fernando saw the writing on the wall in 2006.
They aren't overly interested in winning championships, Carlos ghosen made that clear.
Well Renault are so interested they dont even own the team anymore. Should just go back to being engine suppliers and stop embarassing themselves.
Agreed.
They look likely to do that anyway given the massive fanfare they made about reuniting with Williams F1.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
