Hamilton, Maldonado there sides of the story
pf1
(Maldonado)
Hamilton told his team it was "done deliberately", however, Maldonado insists that wasn't the case.
"It was a difficult moment, there was no reason from my side to have contact and from the side of Lewis," he told the BBC.
"It wasn't rainy conditions and we need to understand what happened. There was no need for contact after the chequered flag."
Pressed as to whether his coming together with Hamilton was deliberate, he said: "No, no, I don't."
(Hamilton)
The Williams was just sitting there, it was very slow. I had to try and get past, which I did
"He came around me, I didn't move anywhere, and he tried to swipe across me. I don't know if it was intentional.
"The front wing was quite badly damaged, the sidepod and I think front suspension was damaged, front toe-in was a little bit out."
He added: "Once the flag was out and the red light was on there is no need to be racing. There should never be an incident but unfortunately there was."
(end result)
the stewards believed Maldonado deserved more of the blame for the incident and have penalised him just five places on Sunday's grid.
Hamilton, though, did not escape entirely as he was given a reprimand.
schumi
pf1
"Well, obviously I would have wished for a different end to today's qualifying, but it is difficult to drive on three wheels - even if I should have the experience to do so in Spa.
"Seriously, this is certainly something that should not occur, but then this is also Formula One; we are working at the highest level but still things can happen.
"At first, I wasn't sure what had happened, as I just felt myself lose the back end suddenly which is why I instantly apologised to the team. But then I saw the wheel off the car and understood the reason why I had lost control.
"Trying to find the good in the bad, I'd probably say that I still have some fresh sets of tyres left, and that there is only one direction to go tomorrow: forward."
do you like my newer shorter post whoring posts?
Having only seen the one vid on youtube, how did Maldonardo get the harsher reprimand?
Lewis was the one ducking and weaving and looked to turn right into the Williams.
I know they were coming up to eau rouge, but if a car is beside you, generally you don't tune into it.
Anyone got other vids of the incident?
Snowie, they have layed concrete at Snowy corner. You are now good to go :)
And because I am a tragic with no life i often go back and watch this over and over...I came so close to holding the lil R400 flat :)
I havent experienced the birth of children, marriage, or much sex for that matter. so sadly, this is truly two of the most fun days of my life :)
100% Hamioltons fault. Moving over on the poor Williams driver...he didnt even have both hands on the steering wheel. Hamo should start from the back row...which puts Webz 2nd :)
i dunno about that. i've looked at both and straight out of the corner hamilton swerves across a little bit then backs out of it. then after that he keeps his steering wheel in pretty much the same spot when the accident occurs. if you watch the incar footage from hamilton you can see that his car stays parrallel to the grip markings the whole time before the crash (other than the initial swerve), while maldonado swerves over to the right hand grip positions then starts to come back across. i think they are both to blame, but maldonado more than hamilton. oh and i'm not much of a hamo fan, so no bias, just going off the footage.
The in-car is the damning footage for Maldonado imo. Hamilton does have a bit of a go as Maldonado pulls out from behind him,hence the reprimand, but then from the in-car Maldonado clearly comes straight across the front of him and continues across the front until he's pretty much on the opposite side of Hamo...
both at fault at monaco. maldonado should've been watching his mirrors and known that sir ramsalot was coming up the inside and to keep well clear. hamo should've realised that he wasn't going to make it and pulled out of it earlier
pf1
Mercedes have launched an investigation into the cause of Michael Schumacher's accident.
Team principal Ross Brawn said: "I'm disappointed for Michael because the conditions would have suited him perfectly.
"We need to look at exactly what happened, but it would appear there was something amiss with the right-rear wheel attachment.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
