Funny how 0.5 sec is an irrelevance in the real world, yet an eternity in F1 terms. damn that quick little barstid
surely 2012 can only get better for him
Year for the second title?.. if somehow the RB8 manages to be a dog all season
hmmm...
Webz has a brain explosion in an interview and puts it on the front row. Only 3 tenths behing Seb in Singapore is a good effort. he has been positively shit around Singapore in past years. lets hope Vettel pulls a heart muscle and gets too hot to bother and Webber can bring it home.
First corner will be interesting :)
mr predictions for tonights race
hamilton takes out vettel at the first corner
button has a relatively ordinary first half of the race then comes home like a baws
webber half a lap down by the time he manages to get to the first corner, then he too comes home like a baws until he tries to shortcut the track by launching himself over the wall, using a slower car as a kicker ramp (valencia 2010 style), and then in the interview asking what happened he just says "yeah, i fucked up"
... What is his longest run of points finishes and when was it?
So getting back Heir Hackness. Maybe I am over stating the significance, but his longest run of points finishes without binning cars and crashing etc was the first 9 races of 2007! His best run of consistant, solid race results was his first ever, 9 F1 races.
To me that says his head was in the right place when he first came into F1. He was focused and most importantly disciplined and as a rookie, no doubt concerned about his arrival and impact in the sport...showed amazing maturity to be so fast and consistant.
Then, he seems to have figured he has proven his point, his discipline disappears and the real, show boat Lewis who is a tad petulant and hot headed turns up to GP weekends, who way too often throws away points for Mclaren...yet still wants to be thought of as one of the best in F1.
Sure, he may be one of the quickest most natural drivers in F1, but results speak volumes and he has thrown away so many points...he needs to get his sh1t together if he doesnt want to go down as a lucky 1 time WDC who in his time was left for dead by the likes of Vettel, Alonso and some of the young punters who are coming up through the ranks
that's pretty much what i tryed to say. :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
