  On 06/10/2011 at 6:28 AM, ctjet said:
bathurst or japanese GP?
V8's>> :iluvff: <<suzuka
Bahaha agreed.
Though looking at the times the end of Bathurst will coincide with the start of the Japanese GP.
Bathurst will probably run overtime though, good old safety cars domokun.gif
roy, you were right...
mark webber.
  Quote
"I'm hearing about a misquote about my plans to fight for the title next year, always possible to miss/add a few words for a good story."
drs zone for suzuka
Edited by tweety bird
  On 06/10/2011 at 7:00 AM, Galois said:
Bahaha agreed.
but before the f1 race you have to listen to Greg Rust and Daryl Beattie for a hour.
Suzuka is the biz-ness. Gotta bring your A-game to cut a good time there.
As I watch the Senna lap I continually have flashbacks to the 11ty+ million laps of it I've done on GT5. lol
  On 05/10/2011 at 9:52 AM, dezz said:
Just got F1 2011, opening sequence is pretty good...Has actual moments from this season, like Hamilton trying to pass Button in Canada and f**king it up lol
Noticeable graphics improvement from 2010?
Kers and Drs?
  On 06/10/2011 at 7:30 PM, sh@un said:
That was just the follow on effect of running a little wide out of degna 1 up the hill. We've all been there.
Its a follow on effect of not slowing the fk down for a corner, possibly two.
  On 06/10/2011 at 10:33 PM, sh@un said:
Sure- tried to carry too much speed through degna 1, then crashed at degna 2 by not being able to brake hard enough for the turn-in thanks to having wheels on the edge of the track
That'd make sense if he hadn't jumped on the gas again out of Degner 1. He had plenty of time to slow down, just chose not to.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
