  On 19/10/2011 at 10:35 AM, sh@un said:
I remember reading the somewhat winding story about that connection a while back, but seem to remember it involves the Honda family and some drama/espionage. bit boring really.
Mugen was founded by Soichirio Hondas son. They damn near won a WDC in the Jordan with Frentzen of all people.
lolwut?
McLaren have had heeeaps of different engine suppliers.
Tidbit: Chrysler/Lamborghini almost ended up as an engine supplier, and the team built a modified MP4/8 to test their 3.5 V12 in
Yes kiddies. They started with all sort sof oddball stuff. Got good with the DFV's, spent huge amount of TAG money to get Porsche to build the V6 motors from 83 - 87, then went Honda, Ford, Peugeot, Merc.
  On 19/10/2011 at 10:53 AM, Galois said:
^I was just reading about that (good old wiki). More tidbits: they went with Peugeot instead, but after a year of poor performance changed to the mercedes engines.
Interesting reading
  On 19/10/2011 at 12:05 PM, sh@un said:
Yes- Went from a 3.5L Ford-Cosworth V8 in '93 to a Peugeot V10 for '94; Which my McLaren history book tells me made 100hp more (740) from the same capacity than the V8 did.
Bollocks I say. Everyone was down on the Ford motor. But the packaging advantages and the massive torque made up for the hp deficit. Not that it was ever what the French made it out to be. In any case the engine McLaren ran was to an older spec than the one in the Benetton. True story.
Edited by djr81
  On 20/10/2011 at 2:42 AM, sh@un said:
If you count a total of 42 points as 'not finishing a race'
not a good season tho
The point wasnt really whether or not the motor somehow once or even twice hung together for the length of a GP. Really McLaren went from belting everyone with a Honda motor to being thereabouts competitive with a second string Ford to being hopeless with the Pug. It got worse in the first year with the Merc - even the fat boy special they made for Mansell was hopeless.
Edited by djr81
  On 20/10/2011 at 3:24 AM, sh@un said:
1!
Exactly. If they were really up on power and reliable do you think the team would have binned them? The Peugeot motor was unloved at McLaren, tolertated/suffered at Jordan until they got the Mugen (at the time it was effectively a factory Honda engine but out the back of the factory through the family ties at Mugen)and Prost never went anywhere.
Hey, I was just stating the bare fact that the Pug 3.5 V10 made (as far as McLaren's own information indicates) 100hp more than the same displacement Ford V8.
It's not like I'm some Peugeot motah fan-boy.
(a quick look at the wiki link reveals a grand total of zero GP's won via Pug power)
Nah and Im not either. Just trying to point out you shouldnt confuse PR bullsht with reliable engineering. There is much more to an engine install in an F1 car than horsepowers on a dyno. Honda had to learn that. Ron Tauranac showed TWR (of all people) that with the Yamaha in the Arrows. Not that it needed proving but the Renault motor has also proved it over the last few years.
If you want to see a good motor have a look at some of the massive aluminium Chevs McLaren used in the M8's and later. Or the Repco motors in the Brabhams. And yes I am an MRD/Ralt fanboy.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
