The barrier is pretty much in the worst possible place, but it's where it needs to be to create the run off and define that part of the track.
The bumpy braking zone is definitely the problem but I agree with sav man, its not supposed to be easy.
IMO make the barrier as effective as possible at absorbing impact and leave those bump strips out of the inside of the chicane to stop cars getting airborne
I like Brundle and Coulthard. They bring intimate knowledge of driving, the tracks and the rules for some good commentary. It must be annoying for them to have to constantly cater to the newest f1 fans though when it comes to explaining things.
Monaco track seems to have not only bumps but things like manhole covers and drains (or things that look like them) all over it. Imagine trying to brake under 4-5 G's then sliding across them. It's a prestigious track but it begs for some big crashes.
Brundle has been losing his shit for a while now. Rambles on all the time and misses some of the most blatantly obvious stuff. Can see him being phased out soon
areed. in the massa (or perez) crash he kept going on about the right rear wheel not being held by the tethers in the crash. I immediately saw it was the left front TYRE that had come flying down (as evidenced by the left front wheel hanging of the car sans tyre) not the right rear wheel and tyre. sure enough when they lifted the car up, 4 wheels attached, only 3 tyres. with all the footage and info they have how do they so constantly stuff things up. he was all excited about pointing out a tether failure which didn't happen. the tyre burst off the rime which was probably more interesting anyway...
maybe he feels without murray walker there talking nonsense it's his turn to be the old fool...
It's part of the charicter of the track, doing stuff like that is how we end up with tilk tracks. It's the most prestigious race to win, it's not meant to be easy. Being a temp street circuit it would probably be easier to move the barrier anyway.
agreed. leave it alone. if 20 out of 22 drivers can manage going over it probably 150 times per race meet and the other 2 go over it 100 times but fk it up once that tells me it's fine as it is. smoothing shit out removes character. sure the tracks have to be driveable but they don't have to be easy. what if they removed what was left of the dipper at bathurst or what about the top of eau rogue where you turn into radillon? that's a crest and car gets light and tries to spit you off. that's what makes tracks interesting.
That bump in the road that they hit just as they enter the braking zone seems to be the cause of all the problems.
It's much smoother in GT5 ^_^
But the ripple-strips at the Pool chicane are hideously violent =[
louie really seems like the only guy thats going to do any damage to that points lead
carn bro, do it for the fans
Skybet sees it as all sewn up already- Lewis is paying $10 to win the title, whereas Seb's a mere $1.13. Say it ain't so :(
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
