Schuey's back!!!
And great to see Schuey and Webber racing hard and clean, including into turn 1 where Hamo felt he had to punt the ther guy rather then give him space...Webber and Schuey and Button made this a GP worth staying up for
yes, until he was robbed of the podium, and we were robbed of the battle yet again, by the ludicrously easy DRS free passes. And not only do they get the free pass, they also get DRS down the next straight to romp away with it. DRS - gayer than aids
I'd say Button had the pace to get him without DRS, but Webber mad eit very obvious he had no answer for Schuey without DRS, both before he had DRS at his disposal and after the DRS walk-over. Even then Weber could't pull away from Schuey despite having a far better car.
point made though - those guys were only faster because of their cars, not the drivers. Least deserving podium ever in history.
Edited by hrd-hr30
The double DRS zone didn't work because there was no secondary detection zone...They needed to have a second detection zone right after the first chicane, so that the car that had just been passed could use the DRS if they managed to stay within 1sec after being passed on the back straight.
Allowing the car that's just made the pass to open his wing just means he's pretty much guaranteed to hold the position, unless the car that was passed on the back straight was within 1sec of a car in front of him as well...
The 2 zones/detection points should've been completely independent of each other
the double DRS zone worked exactly as intended/designed. the whole point of DRS is not to encourage racing, its to ensure there's passing so noone can criticise F1 in the media about the lack of overtaking like they used to.
Haha, sounds like a lot happened after I went to sleep (about 25laps in, still under saftey car).
Definitely downloading when I get home from work.
Can't wait to see the post race interview. :D
fell asleep at some point in the red flag but probably drifted off a few times under the safety car. I want kobayashi's autograph, hiedfeld for the most part was pretty stellar and about jb and hamo, all hamo, jb took his 1 defensive turn in, hamo was the idiot who didn't get out of the throttle. If the roles were reversed I'm positive hamo would have shut the door, hamo gets away with to much shit from his popularity in the media.
I have to admit, I wooped the shit up when vetel stepped the back out, nice recovery but half seemed to do it almost on purpose or maybe he was tired, seemed like a seriously uncharacteristic mistake from a quick dude, maybe he just really didn't have the confidence in the wet?
Either way, I wanted to watch jb win. Not enough visuals of his misses, maybe some wet top action with the champagne spraying her or something. :cheers:
After watching it again today you can see that Vettel swept wide on the same corner the second last lap with JB keeping well away from the edge of the dry line. Next time around he was a whisker wider and that's all folks.
I agree with Dezz if there should be a second activation point for DRS.
I think that's the way the whole world was expecting it to work - the car that got passed in the first DRS zone would get a go in the 2nd zone. Not the car that just passed him! what were they thinking?
but the fundamental problem with DRS is it takes the sport out of the racing. Its just a free uncontested pass, irrespective of the stupid second zone
Where is the best place to download the coverage?
Or... Get a TV that can record. I recorded it after the red flag, glad I did because it went on for another 3 hours :\ Would have slept at work.
At one point he was last, stopped 6 times, had a drive through and still won. Legend.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
