I've been saying that since the mid 90's and here we are lol.....
my new formula would be:
3.0 Litre DOHC 5 valve per cylinder max twin turbo V10.
Or upto 8 Litre naturally aspirated, any configuration.
Free aero, apart from front and rear wing wake and air disturbance massively reduced.
Full ground effects floor, tunnel and diffuser allowed.
No kers or any other device of this nature.
alcohol based fuel.
minimum two tyre manufacturers.
cockpit equalised so that no driver is held back by weight or size.
Larger tyres, much different profiles, probably 18"
If full ground effects were allowed back (sliding skirts, tunnes... etc) the cars would have tiny wings anyway, regardless of rules.
I think the old 1.5 turbo or 3.5 na is the way to go, but leave the piston count and layout free. The turbo tech that would come out of low capasity engines would be great
by the looks of the rule changes...i dont think i'll be watching after 2013 anyways. so they can all do what they like
good point. I figure if I up my alchol consumption by about 30% I will soon forget all the WDC results from 1985 to 2000 and I can then just re-warch those 15 years of F1 over and over again...
yeah agreed. 3l turbo and 8L na is waaay too big. get them to make a max 1.5L turbo or 3L na as the maximums. they can easily get 800hp-1000hp from either 1.5L turbo or a 3L v10 NA so then they get to chose reliability (800hp) or power (1000hp). or spend more and have both!
if really generous up it to 2L turbo and 3.5L NA. that is plenty.
I like the idea of cockpit rules though and perhaps raise min weights so that fat drviers aren't penalised! lol. i'm sure there's some talented fatties out there... would surely help webber to be on an even keel weight wise with vettel. he is giving away probably half a tenth per lap in body weight penalty alone.
....actually the way Raikonnen is going on the tooth he might need an extra widebody F1 car if he makes a come back.
I wonder what mods they made to get Tony Stewart in the MP4-23 did they graft the A to B pillars from a BA Falcon with a seat located in the middle to fit him in? It would have left room for space to sit a pizza, a couple of burgers and cupholders for a big gulp.
I would love to see more taller/bigger drivers have a shot at F1 but realistically it is a sport for rich midgets.
alcohol based fuel.
then i'd def be watching. :)
sadly.....very unlikely
I'd be happy to keep the current capacity, what is it 2.4L? They can make plenty of power from that capacity these days. But allow whatever configuration they want to run as far as how many cylinders etc, and have no rev limit.
It could give some more variety in the field, the way its going it will be a common pretty much everything ala V8 Supertaxi's in a few years.
No rev limit could potentially reward teams willing to push the limits of engine reliability if they can hold them together. I don't see the problem with that because they already get penalised for using too many engines anyway, so why not let them push the envelope of reliability?
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
