1 bar? :sick: Pretty poor when road cars can safely run higher boost :rant:. Not that we'll ever see 5-bar 1300 bhp engines again, more's the pity
don't know why so many people get hung up on boost. champ cars made over 800hp with less than 3psi. just need some revs. 1.6L V6 pulling big revs on 1 bar boost could make enormous amounts of power with current electronic systems. they'll certainly be running restrictors to cap power.
Boost is only a measure of restriction...
And 500KW at 5,000RPM and 1000KW at 10,000 is the same amount of go fasts... ... ... :P
Torque people... It's all about torque... :P
Ok, I will take the second engine and you take the first, and we shall race....
Garbage. This is the most persistent misconception in the history of performance vehicles.
Power and gearing is what determines acceleration and top speed, NOT the torque figure. You can make up for a lack of torque with shorter overall gearing, but you can never make up for a lack of power the same way.
If torque mattered more than power for foot-down stonk, you'd look at torque-to-weight ratios to compare performance potential, but it's power-to-weight that matters.
It's funny then how my 260kw 1800kg R35 GTR was able to beat my 380kw 1600kgs R34 GT-R in a straight line drag race.
So power-weight isn't everything.
Anyhoo - HRT has been sold to the Japs. Kings of the turbo 6's. Let's see what happens to them now.
power and torque, forever linked.
BUT Cmon Hoss, dem 2.6 litres just dun hav enuf of the tork to be fast not like me 454 V8.
nissan??
rb16??
You never know.
Remember what RBR was before they were Redbull... and how successful they were.
Well any similarity between anything called HRT and a proper race team is entirely coincidental.
For that matter any similarity between a race team owned by an investment bank and a successful race team is entirely coincidental. Look at how "Renault" are going backwards for instance.
Renault pioneered the turbo charged formula one motor.
Nissan on the other hand have never even built an F1 motor of any sort.
So what would Nissan possibly be able to help them with?
this is true. one can only dream.. i was just happy to see infinity on the rb6 this year..
So ... does anyone rate Ricciardo a long term chance?
In the short term at least I think he's going to give Liuzzi a real touch up. And Buemi and Alguersuari will be thumb-wrestling for the remaining seat at STR next year
Personally I'd love to see him make the next step (ie out of a shitter and into a top 10 car). But unfortunately it is probably as big a step as getting a start in the first place. Far too much luck involved...always has been.
BTW Liuzzi is no hack, and I'm not convinced Karthekeyan was either. Put anyone in a shitter and they will have a hard time too
yep, and Luizzi has heaps of F1 experience. You can bet he'll be motivated to beat the hotshot rookie too. Ricciardo is good, but don't expect too much for the first few races is my tip. I'd say racing the HRT will be a very different kettle of fish to testing the Red Bull.
Ricciardo has to be looking good as a long term prospect. He's still slated for Torro Rosso next year, which is the same path RBR put Vettel through. He's got the opportunity and certainly seems to have the speed & ability.
Edited by hrd-hr30
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
