So its pretty much stock S2 stagea with blitz air filter and exhaust with sbc i colour, i have a little box in the passenger footwell with SIDC box???
it has a mines ecu with :
Fuel mapping has been changed
Ignition timing adjusted
Speed limiter cut
Rev limiter raised plus(+) 300rpm
Guys at autoworx recomending i get a new fuel pump.
I want to get a new ecu as it is.
here is dyno sheet, i believe this is on mid level boost....
https://www.sau.com.au/forums/topic/344518-just-had-my-car-dynod/
Nope.
It is kind of like a piggy back but is sort of like a completely new ECU. It is additional 'address space' and kind of interrupts the factory default values and is placed inside the factory ECU.
This basically allows you to have full adjustment of pretty much everything via the consult port via some cheap laptop software downloaded from the nistune website. For example, I can now change the Thermo fan set point which was usually an 'emergency thermo' for my SR20DET. I've removed the factory clutch fan and now the ECU takes care of cooling duties!
hay man that mines ecu you have the best thing to do with it is to remove it and throw it in the bin !!!!! my mate had one in his 33 and it caused all kinds of problems for him and never tuned properly , and would always lean out on a high boost setting and could never hold a smooth AFR for some unknown reason . seriously man the best thing to to is to spend the 400 bucks on a nistune daughter board installed into a STD ecu and all your problems will be solved . my s2 before i installed the nistune was pulling 235 hp on 10 psi , and 2.5 exhaust std cooler and turbo smart boost tee . now i have a 3'' exhaust , FMIC and coustom intake setup , but i havent had it tuned yet because of getting hit in the ass by a stupid ford driver and having to get it fixed but now i have it back so it should be all go after christmas , and im hoping for around 290 -320 hp at all fours with a goog tuner . cheers spinner ..
How much are they normally
See if this one's still for sale - I think he wanted $400 for the ecu c/w nistune chip - you could just plug it in an get a tune.
http://www.skylinesaustralia.com/forums/Ni...fm-t340680.html
+1
$450 I recall for the ECU.
Thats if its still available. The thread was killed by some non-buyers tearing at it.
The board itself is about $280, a single user license for the NIStune software is $200 I think (you don't need this, it's only if you want to be able to fiddle with stuff yourself, or ask me to do it :) ) - both purchased straight from NIStune.
Carton of beer to a competent electronics technician to install the board.
Then find your tuner of choice (I can recommend Hyperdrive and Allstar Garage) and pay by the hour for tuning. Shouldn't take too long as it's pretty much stock.
Edited by bubba
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
