I am looking for a r32 GTR front bumper in plastic, any condition or colour!!
Try one of the importers as they may be able to get you one new from japan ( or second hand) and prices for OEM stuff in Japan is alot less then they are here.
$578. - just ordered one.
Realistically that's not too bad, did you try one of the importers I know RHDJapan can get alot of OEM stuff for a good price.
realistically I could have sourced it ex nagoya but by the time I did it for a saving of $50 it was easier to source local. I deal a fair it with japan nowadays but freight on an item that size is a killer.
does that include the lower lip as well?
no. that is only the front bumper cover. the lower lip is extra - I have the price for it at the shop. from memory its roughly a $300 piece.)
in all there are 20 or so pieces to the front of it. for those that simply want the 'cover' then the above is correct. I'm doing the lot so I'll have prices for most of it fairly soon.
  • 4 weeks later...
  • 4 months later...
spewing i thru mine out i would of given it to you i only needed glassing the bottom bit back on i just couldnt be bothered withit so thru it out with my shell :(
JESUS!
The price from nissan retail is $700 with clips etc. included (staff price is closer to $500) and this doesn't include the lower lip.. that'll be an extra $400!
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
