specs
GT3071R garrett ball bearing turbo
comp housing
0.50a/r
inducer wheel diameter 53.1mm
exducer wheel diameter 71.0mm
trim 56
exhaust housing
0.64 a/r (mod 21u)
turbine wheel diameter 56.5mm
trim 84
Was told and I thought should make 260...but it isnt, thinking it would be better suited to a rb20
Edited by Arthur T3
exhaust housing
0.64 a/r (mod 21u)
trim 84
So what is it making - somewhere around 230-235?
Looks like you've got a milled (high flowed) OEM turbine housing. If so I think you'll find they're somewhat smaller than 0.63, but there is no marking on them to indicate. Might not be a good match with the rotor, can lead to a bit of choking and below expected outputs.
You might do well to consult with a turbo manufacturer/remanufacturer about housings - perhaps Hypergear can help out if that is the culprit.
yeah its making a solid 240..
and spoke to hypergear a while back who straight up recomended a bigger rear housing..
But for that amount of trouble Id consider just getting a better turbo..
might just run some e85 see what happens...I got no problems with the power ,thought it would be a tad more responsive for what it is really. And its kind of odd having a turbo that comes onto boost but doesnt really make alot more power than it did b4..It pulls hard but there's not that boost kick .Not to worry..I should stop complaining and just be happy its running again. ;)
its very tempting, I dont think there is any point trying to get anything more out of this one pretty much maxed out already..
And i could probably get the same power from a 2871 with far better response
I have a bad habit of jumping in the deep end, i did plenty of research after i bought it.. ;)
Edited by Arthur T3
It helps to know what characteristics you want before you start. Some combinations are deceptively fast ie. cover ground quickly and don't feel it. Despite the power number, it might deliver the goods if you can directly compare with something else.
I'd be interested to see a dyno sheet, even if it only tells part of the story... :rofl:
Well you've already asked someone who is a specialist in the field. I wouldn't think that a housing upgrade would cost the earth, and if it stops the thing choking up high then trialling it would be worthwhile. You may also find that any loss of response is academic when you look at the entire picture.
You might be surprised what a bigger turbine housing will do, and the extra ignition timing that it allows you to run. If you went with a -32 spec 2871 all you would get is a smaller turbine rotor with the same sized compressor :P FWIW, I found a -31 spec (ie 48 trim) GT2871 high flow very good, progressive and fast with 225rwkW. Never looked fast but it really covered ground nicely for a road car.
Edited by Dale FZ1
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
