gday bought this last week let us know what you guys think.
330HP at the rear wheels running 1.2 bar
Nismo Fuel Pump,
HKS cat back. 3 inch 3 inch dump pipe,
HKS 25/35 turbo,
Sard 550cc injectors,
Apexi air filter and after market air separator from engine, Z32 AFM
4ws HICAS lockout bar. (Installed and tuned by WA Suspensions),
Coil over's. TEIN HR, also Wa Suspensions.
GTR 17 x 8 inch wheels, wearing Federal 959 RS Semi Slicks. Insane Grip 2 sec 60 ft,
Front Strut Bar,
B Pillar Brace,
Front Mount Cooler plus stainless piping,
DVD player. Kenwood touch screen, 2 10Inch Subs in box, 2 amps, MTX powering the SUBs,
2500 pound clutch, Ceremic plate
Coil Packs by Splitfire,
Nismo gear Nob and leather covers.
Has original floor mats,
Air Bag standard,
Turbo timer installed in Japan before export.
R33 GTR front bar.
Apexi AVCR boost controller,
Apexi Power FC plus hand controller
https://www.sau.com.au/forums/topic/344549-r33-gtst-4-door/
246rwk would be fun in one of those , what's the 2530 like? wheezy up top at all? when does it actually hit full/peak boost? . gtr rims are 17x9 btw >_<
yeah alot of fun. pretty hairy 1st and 2nd. i havnt found it to be wheezy at all. think its about 5000rpm ish. oh really i just copied and pasted the mod list from the old owner
https://www.sau.com.au/forums/topic/344549-r33-gtst-4-door/#findComment-5553053
  • 11 months later...
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
