late 94 nissan skyline r33 gtst
5 speed manual
60000kms
Custom colour (candy peakock blue)
17 inch deep dish racing wheels
Full body kit (400r front bar, side skirts, rear pods, GTr wing)
Sunroof
BIG BLITZ fmic
APEXi air filter
Turbosmart dual stage boost controller
pioneer cd player with remote
clarion 6 inch in dash tv
500wrms 5 channel response amp
clarion 6 inch splits
2 12 inch subs in box
strut brace
$18900 negotiable, $18000 without tv and cd player. reason for selling is due to the fact that i am now after a r32 GTR or s15. call me on 0415161056 or email me on [email protected]. no time wasters please.
cheers
cheers
https://www.sau.com.au/forums/topic/34455-fs-skyline-r33-bargain/
  • 3 weeks later...
PIcs pls very interested! [email protected]
5 speed manual
60000kms
Sunroof
BIG BLITZ fmic
APEXi air filter
strut brace
cheers
cheers
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
