would change AFRs aka just dump in more fuel making the car richer.
that's that i would guess for $12.
Exactly. Tricks the car into thinking it's colder, therefore dumping more fuel into the engine. Will it work? Marginally. Is it terrible for your engine? Well...
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5553410
It changes the signal for the coolant temp sensor not the air temp.
But yeah...cant see it doing anything other than washing all the oil off the bores and ass raping your engine with a pineapple attached to a jousting stick.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5553795
It will modify any standard ECU by telling the ECU that the incoming air in the intake system is cold
description makes it sound like it's for a air intake temp sensor.
you could essentially just unplug your coolant temp sensor though. will have the same effect. the thing is though, on long trips it may really affect fuel economy if the resisitor in the little box (that's all they are) made the ecu think the engine temp was so low that it ignored the o2 sensor and just ran on the cold start enrichment maps.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5554012
also won't work on rb20 or rb25 powered cars as they don't have an intake air temp sensor.
i'd also like to know how adding in more fuel (which they say happens in the explanation) equals better fuel economy, lol
I knocked my temp sensor off one day to the ECU, car wasn't too happy about it once warmed up.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5554024
It could and has worked before.. you just gotta know what it actually tries to do so you don't expect too much.
Generally these resistor/chip/box mods will tap into the coolant temp sensor and lower/raise the resistance value fed into the ecu (depending on the type of sensor you have - some go higher when hotter whereas some go lower when hotter), then once the ecu picks up that the car is supposedly running in a cool environment, it will advance the ignition timing to suit equaling more power.
The main thing it depends on is your OEM ecu having ignition timing advance for colder situations - if the ecu has that and you install this crap correctly, then it will work to an extent.. much like driving some bog stock normal car in 10degree night weather vs a hot summer day (taking into account the air is less o2 rich during your testing the device vs driving during a really cold night and also heatsoak).
You can potentially save fuel by having to be on the gas a little less going up hills or maintaining speed etc as your car will have slightly more torque so you do not need to depress the throttle as much as before the 'mod'.
Long as you have basic electronics understanding, how car systems/ecu works etc, you can do this for a couple of bucks (buy a pot to see which resistance value gives best results then buy a simple resistor in that value).
While it may seem like i'm giving this a good rep.. nope not at all (not saying it won't work either because done right it will as long as your ecu has timing advance for colder running situations, a coolant temp sensor and a conservative factory tune). But it's sometimes nice to know the theory behind things.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5563746
most ecu's add more fuel when cold, as well as possibly adding more timing, so when at full throttle you will use more fuel, and when cruising you may simply use the same amount of fuel. all in all though, you would normally see worse fuel economy with something like this. i've had cars with dodgy thermostats making the car run cooler and fuel economy was better once the thermostat was replaced.
https://www.sau.com.au/forums/topic/344550-what-is-this/#findComment-5563937
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
