Hi
I just orderd myself a whiteline plus adjustable camber kit for the rear of my r33 gtr, just want to make sure im going to be mounting the bush in the right place.
Am i meant to mount the new adjustable bush in the rear upper camber arm (the rear upper camber arm has a fork mount on one end were it bolts to the hub and a rubber bush on the other end were it bolts to the subframe mount), do i remove this and replace the factory bush with the whiteline adjustable bush?
Or do i remove the hub and replace the factory bush with the whiteline bush were the rear camber arm bolts to the bush on the hub?
Am 99% sure i put the new bush in the camber arm but just want to make 100% i am putting the bush in the correct place before i install them.
Hope this makes sense lol
Cheers
Jason
https://www.sau.com.au/forums/topic/344566-whiteline-rear-camber-kit-r33/
Need some help asap.
Just about to install the rear camber bushes now, but it looks like the end of the rear upper arm already has factory camber adjustment (never knew gtr's had adjustable camber on the rear from factory)???
The bolt that goes through the rear of the arm with the bush already has a big offset washer with degree markings on it, when you turn this bolt it moves the top of the hub, hence giving you the ability to adjust positive or negative camber.
Do i mount the new bush in the hub now then??
Your correct, replace the standard kit on the outside. I'm not sure if the kit give more than the standard, but you may want
to do the inner as well.
http://www.whiteline.com.au/instruction/206_KCA347.pdf
the factory inner only gives you about -/+ 0.25 degrees of adjustment. The whiteline will give you -/+ 0.75 degrees or so. both of these are usually enough to correct camber unless you're running super low in which case you need to replace the inners as well.
  • 1 month later...
How hard is it to remove the hub assembly to do the 2nd rear camber kit?
Tossing up whether to get both the inner and outer bushes... planning to lower the rear to about 320mm but don't want huge neg camber
Anyone had both sets of bushes installed?
cheers
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
