hi , any help would be nice , i have a 1990 r32 and i have a few problems i need help with
1- when i turn my car off and the turbo timer is running the car starts to idle rough and dies b for the turbo timer shuts off.
2-clicking noise under my bonnet also when the turbo timer is on think it might b the hicas any reason y it would do this ?
3-fuel pump cuts out around corners sometimes , replaced with 550hp walbo pump no difference
https://www.sau.com.au/forums/topic/344592-r32-problems/
lots of electrical issues..
is the turbo timer wired in with an alarm, if its standalone, take it out and re-install properly, also will help determine if the clicking noise under bonnet is related to turbo timer
is the fuel pump attached to stock cradle, how far down is installed? how much fuel did u have when it happened? has it still got the sock filter?
Edited by BWRGTR
https://www.sau.com.au/forums/topic/344592-r32-problems/#findComment-5553724
not sure will have alook when stops raining for the timer , no alarm installed , the fuel pump problem was also doing it with the stock pump
https://www.sau.com.au/forums/topic/344592-r32-problems/#findComment-5553752
