well as some of you know, i did end up selling my beloved GTT - my first Skyline and certainly provided many years of enjoyment since 2006 (technically owned since 2004), from DECA to GOR to the Spur/Reefton, Sandown etc - the car received a fantastic response over the years and really was good to me. Never any major mechanical issues, just coilpacks was the only thing replaced- car was bulletproof and looking back at these brought the sadness of saying goodbye back...
The car is now in Canberra, and i met the new owner at Macca's at melb airport a few months ago for the handover...
going...
going...
gone :(
as the new owner hit rev limiter exiting Macca's :(, that was last i saw of her... maybe one day i'll have her back in the garage
a thoroughly disheartening experience, was so sad to see her go :( tears were indeed shed, i will not lie
i know some of you have wondered if i had lost the plot by selling my GTT, or were curious about what i would replace such a beautiful car with? in my mind, i drew a line in the sand about spending anymore money on the GTT when there was a car i still really want to own...
i looked locally, whilst there was a lot of choice, there wasn't anything that really stood out or was perfect in one way but too compromised in another. So just like my GTT, i went looking back in the spiritual home of most our cars, Japan.
I still at this stage had not 100% decided i was going to get anything (the search began earlier this year) but something ended up catching my eye and the more i looked into it, the more i realised i needed to get this car. I am FAR from an impulse buyer, and usually like to research everything to the small hours of the morning but i saw her and said, that's the one. After an initial scare with other interested parties, the car was secured and on her way to our fair shores.
Some know of this car already, some don't, so without further-a-do, i present the new member to the family, my new R34.
(i suck at photography, hopefully get some good ones taken soon)
There really was only one way i could go after the GT-T and i decided to take the plunge. And as you can see, this 34 is a touch more serious than the previous one :D
2002 V-Spec II Nur
Built by Midori, one of Japan's top GTR workshops and one of a select few to be approved R34 GTR specialists by Nissan
Single owner in Japan from new :laugh:
That's the basics, now for the bits i guess most people are interested.... modifications, we received most the receipts for the car, not everything, but have managed to decipher this from the documentation received.
MIDORI Fine Tune engine maintenance – Overhauled and balanced
Engine blocked cleaned
”WPC processing” - (this is very cool, google it)
Fitted N1 pistons
Balanced connecting rods and pistons
Midori Intake and Exhaust Camshafts (256 degree duration and 9.15mm lift both sides)
Cleaning of Cylinder Head
PBB Replacement Valve Guides
Valve clearances set
Measuring valve spring replacement
Measuring valve spring adjustment
New Valve seats cut
New Valve seat rings
Valve face polishing (removes Nissan logo and smoothes valve surface)
Combustion chambers CC balanced and porting modification
0.8m Cylinder head re-surfaced/decked
HKS 1.2mm Metal Head Gasket fitted
Camshaft Oil seal replaced
N1 oil pump replaced
Valve stem oil seal replaced
MIDORI original development Oil Pan Baffle kit
MIDORI original development Oil Catch Tank kit
NISMO Inlet Piping kit
NISMO Air Flow Meter x2
OKADA PROJECT Plasma Booster Direct Ignition system
NISMO reinforced engine mount kit
SAMCO silicone heater hose kit
HKS GT2530 turbine kit x2
HKS upgraded adjustable wastegate actuators X 2
MIDORI original development Turbine Dump Pipes
TOMEI EXPREME exhaust manifold kit
NISMO intake manifold/Plenum
HKS Inlet manifold metal gaskets
MIDORI original exhaust front pipes
MIDORI original High Flow metal catalytic converter
MIDORI original development Silent High Power Full Titanium Exhaust System - (silent?? hahahah.... yeah.... very silent :P)
HKS Power Air Flow “Reloaded” Version
SAMCO Silicone Suction Piping/Turbo intake piping
ARC intercooler model M079 (hand fluted intake side, premium ARC core)
SAMCO Silicone upper intake piping (black)
HKS Oil Cooler kit Type S, with duct and 15 row core
CALSONIC Aluminum radiator
CALSONIC radiator cap
SAMCO Silicone radiator hose kit
NISMO 600cc Fuel Injectors X 6
TRUST Fuel Injector Rail kit
SARD adjustable Fuel Pressure Regulator
NISMO 248 L/h High Volume Fuel Pump
MIDORI development ARAGOSTA ERS custom modified suspension (damping force adjustable)
EIBACH springs
BCNR33 Front Lower Control Arms
MIDORI Development Pillow ball tension rods (castor rods – rose jointed)
NISMO reinforced Upper link/Upper Control Arm Bushes
MIDORI development Rear Pillow Ball Upper Links bush replacement (rose joint bushes in upper control arms)
MIDORI Lower Arm Pillow ball bush replacement
MIDORI rear sub-frame collars
NISMO upgraded rear sub-frame bushes
MIDORI development Front Tower Bar with integrated Master Cylinder Brace (custom made)
MIDORI Development Front Lower Brace Bar
ATS Carbon Fibre Twin Plate Clutch
MIDORI development ALCON MONO6 355mm (front)
Monobloc calipers-ALCON 6POT
J hook-ALCON 355mm 3 piece brake rotors
MIDORI development ALCON MONO4 355mm Rear Brake kit
Monobloc calipers-ALCON 4POT
355mm 2 piece Alcon Brake Rotors
FERODO DS2500 brake pads front and rear
APP Stainless Braided Teflon Brake Lines
MIDORI original development Clutch Slave Cylinder
NISMO upgraded gearbox mount
NISMO LIMITED BLACK GT500 LM-GT4 18 x 9.5 +12
ADVAN NEOVA 265/35-18 Tyres
MIDORI original custom tuned ECU
NISMO MFD expansion kit
HKS EVC 5 Boost Controller
NISMO 320km Full Scale Meter Kit
NISMO Side skirts
NISMO Rear side pods
MIDORI Development Carbon Fibre rear Wing Mounts (raised)
Front lip Spoiler painted body colour
NISMO Duracon Shift Knob (changed to GT500 Titanium)
Nissan TV option kit fitted
SONY navigation system
There has been a lot of suspension work done on this car, it's a very serious setup and perhaps not the best street setup :D but besides the springs being around 12/13kg, the shocks actually do a very job of providing a pretty decent ride i must say.
A few things need to be sorted before the track work can begin, but can't wait to get it out there and see what she can really do. So far, the grip that can be generated from the little play time i've had is fairly freaky, team cheater indeed :D
Thanks for those who respected my wishes to keep the car on the quiet side for the time being, much appreciated :)
sorry for the essay!
cheers,
chinny
https://www.sau.com.au/forums/topic/344597-goodbye-my-gtt-and-welcome/
  • Replies 109
gone :D
as the new owner hit rev limiter exiting Macca's :D, that was last i saw of her... maybe one day i'll have her back in the garage
:laugh::D err that's not the way to canberra.
he's goin southbound on the tulla which takes him back to the city.
Oh and yeah, congrats on the new beast chinny! :P
saw this at the show and shine and would like to see that it is very sexy
+ 11ty.
Daniel,
The underside looked serious than it appears.
I have one criticism though, the black wheels doesn't really suit the dark silver/grey (what is the colour called by the way?), I'd say bronze would look better but it's just my 2c.
Aside that, beautiful car mate, it has certainly make my 33 GTR look boring as Audi!
Hope you'll enjoy it for many years to come.
Cheers
Grant
Is that the same GTR that was at the show n shine on the weekend?
very sexy car I must say.
If cars must be brought in stock to Aust how exactly were you able to bring that in and comply it when it is so modded? or have the mods been done since its arrival?
mods were done after compliance. :laugh:
Basti, you mean about detailing it? already has been, attacked it before the S'n'S, but silver doesn't really yield the same results as black does unfortunately. I've got some metallic/flake shots somewhere to show the paint correction though :laugh: I was secretly hoping it was going to rain on Sunday, would have been fun to see the water slide off the car
Hey you were at trent's a couple weeks ago werent you? I was the guy with the white gtt waiting to go on the dyno.
I didnt know who you were on the forums forgot to ask your name :laugh:
Awesome gtt and now this insane gtr, it looks fantastic man congrats.
Mad GTR!
Looks awesome Dan!
Z-Tune front guards are next... Right..?
:laugh:
nope, for sale - was going to put a bunch of JSAI stuff on but i was happy with how the car looked when it arrived, so they're up for sale :D
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
