Hi all, basicly im looking at doing a motor conversion on my gts4 early early next year - starting to prep my shit soonish
Just wondoing if anybody has down a conversion involving a rb25de 4wd motor out of r33 gts4 - and sticking it in to there r32 gts4 im wanting to scrap the rb20, and seriously looking at doing a rb25de+t
Just wondoing if its simply a bolt in conversion,
or am i going to have to look at diff ratios etc?
basicly info i need to know before me and my mechcanic get down to bizzo!
Cheers
NS.
https://www.sau.com.au/forums/topic/344614-4wd-conversion/
I would imagine there would be quite a bit of wiring change going from a RB20DET to a RB25DE motor but i could be wrong. My personal recommendation is that you get a R32 GTR front cut with wiring loom, motor/box and just swap everything straight over. If your bored like me with the RB20 because it doesn't cut the cake, stick a RB26 in it. Heres a link to my engine conversion going from a RB20 to a RB26 on my R32 GTS4 4 door. It was a very easy job to do. RB26DETT Into A Gts-4 Conversion
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5554035
Im running a linkG4 at the moment, I know i have to get a VCT controller wired up to the link as ill be utilizing the VCT,
more my quires are focused at is fittiment, diff ratios, mechcanical drive line and 4wd fittment.
im using uprated coil packs and have been told that i am able to runn these on the rb25de - but they would not fit if i was to use a stock rb25det motor>?.
deffinate knowledge from people who have done the conversion/Knows RB series engines inside out(what fits what between models) - would be much appriciated!
:laugh:
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5554070
dun it 2 an r33, everything was a bolt on. havnt seen on an r32 but seems your gna need to replace looms and ecu obviously but not 100% how the ratios go.......ps i got a stagea rb25 if your interested :laugh:
Edited by OoskylineoO
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5554097
If you follow blind elks posts, there is plenty of detail about Stagea rb25 into r32gts4. I'm doing this swap slowly. I think the rb26 is worth considering these days, the cost is lower than it used to be. Power - the point of a swap is higher. State laws may impact as well. An RB26 can put out power looking close to stock.
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5554617
The other option is to sell it and buy an R32 GTR , at least then (provided its sort of original) its all designed to work as a package . I think diff ratios are taller in a GTR and they are not that easy to change - front anyway .
I kind of think a lot of money could be spent here and its never going to have the sort of resale vale a GTR would .
The cost effective approach if your car doesn't do what you want it to is to replace it with something std thats a lot closer to your liking in std form . Then mild mods if its not enough .
Sadly its almost impossible to beat factory engineering and economies of scale on price . They can build it a LOT cheaper than you can so its a case of finding something thats affordable and no too old or used up .
A .
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5555339
A .
A GTS 4 project often starts 10- 15k dollars lower than a GTR. I still think GTR is the ultimate!
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5555389
Ok so basicly the rb25det 4wd motor from a stagea will bolt strait in to my r32 gts4?
And the same goes for the rb25de 33gts4 motor correct?
-Yeah sorry Kiwirs4t i was meaning i just needa get the cable! im in the know about what the link can and cant do.
-sorry discopotato03 i dont have 20 to 25k to spend on a gtr, nice thort tho:)
Hmm seems the neo gts4 motor is harder to come by. ill be hunting around for abit id emagine
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5555653
Both "bolt in" as will the RB26, if you can't get a neo engine, you can get a neo head.
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5555858
Ok thanks for that one white, so with the diff ratios basicly i can keep using my excisting diff (center and rear) how ever the power is going to spin them up to quick so its in my best interests to upgrade to for example a stegeas center and rear diff?
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5557328
There is no centre diff, there is a front and rear with a clutched transfer case to join them when required.
You need to keep matching ratios front and rear.
Stagea ratios are taller, meaning you will trade acceleration for top end (minimal, 4.3 to 4.08 isn't a huge jump). Personally I would keep the 4.3 you already have, it will help get future bigger turbos on to boost sooner.
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5557429
  • 1 month later...
Will a rb25de 4wd block bolt to my rb20det 4wd sump? ive been told it will, any other comments on this?
thanks
Sending your sump to performance metal craft for enlargement, baffles and pick up can help oiling issues later.
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5598348
So in saying that it would be possible to bolt any 25det/25de/26dett motor in to my 4wd sump, dosent matter weather its a 4wd motor or just Rwd?
It has to be from a 4WD.. only 4WD blocks have provision for the 4WD sump.
To bolt a RWD block in to a 4WD you would need to run an adapter plate like the one used to put RB30 bottom ends in GTR's/GTS4's/etc.
And if you're going to do that, just build a 3L for it :)
https://www.sau.com.au/forums/topic/344614-4wd-conversion/#findComment-5598569
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
