For Sale: Was collecting parts in anticipation i would build a beauty. However have purchased a VN 5.0L and enough's enough.
RB25 greddy copy plenum with
big throttle body and TPS
Bosch top feed injectors 638cc
new injector loom with new gtr resistor pack
custom top feed rail
turbo smart fuel reg
speed flow fittings
$1200
Rb30det in 2 parts head and block
r33 s2 complete head modded to suit rb30 block
has everything to bolt to rb30 block as it was an RB30det no long ago.
includes
rb25det oil pump
multi layer metal head gasket
timing belt
coilpacks
alt
s2 rb25 loom
rb20 remap made 300rwkw old at the wheels
550cc injectors
custom forward facing plenum
Q45 air flow meter
flash rocker covers with speed flow catch can fittings
rb30na block, from vl commodore s2, has done 180,000kms, really good condition (not pictured)
NO turbo or exhaust manifold
$1600
post-25639-12898755692402_thumb.jpgpost-25639-128987558809_thumb.jpgpost-25639-1289875613068_thumb.jpg
Turbo kit- under 2000kms old
GT35/82r roller bearing garret turbo. 0.7 front cover, .64 rear exhaust
heat rap stainless maniold. not the real cheap ones off ebay, cost $600 new
tial 38mm external gate with screamer and vac lines
braided oil and water lines
3 inch dump pipe, joins to factory position cat on r33, believe it will fit r32/r34. this was on an rb25det. NOT the RB30DET.
turbo inlet pipe, reduces to suit z32 air flow meter
will make easy 300wrkw on rb25
$2300
Trust 100mm intercooler, has been damaged and repaired, no leaks
$300
Bosch external 910 fuel pump
$100
Microtech LTX12
no loom or hand controller, comes as is in picture
good condition tuned for rb25det, gt25/30 turbo, 550cc injectors
$500
RB30ET stainless exhaust maniold, ebay job
never used
$200
turbo T3-T4 adaptor
$100
ATS carbon twin plate clutch kit.
complete kit with thrust bearing
was slipping when in my car but plates still have meat.
may be a pressure plate issue.
this is big dollar clutch when new
$300
Located: Adelaide
Contact: PM
Prices: As stated. Am open to offers via PM.
may separate.
I can organise postage if needed
Edited by peripheral port
  • 4 months later...
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
    • Pour in the highest octane, non-ethanol fuel you can get and see if the readout changes. If it's dead bang on 11% then I would question the sensor. Another quick test, just take it out and run normal (in an american accent) gas-o-line through it and see if the sampled ethanol or lack of changes.   United E85 here in the land of drop bears does vary a bit, I've had as high as E87 (could be water in their tanks too, who knows)
    • Yep. And if you ever do, you'll just have to deal with it then.
    • E10 is pretty tightly regulated in percentage. Too much and engines can't adapt. Every incentive is against them to have too little ethanol though. The more ethanol the higher the octane.
