Hey guys,
Just got my skyline yesterday, but while driving at night I noticed I couldnt see how fast I was going, nor at what rpm or anything else. The back part of the dash lights up green, but its not very bright at all, and the red pointer things dont light up at all ?
I dont have a dimmer switch, looks like the workshop didnt fit them.
I've taken the dash apart, but I really have no idea what to do.
Any ideas ?
Thanks heaps
https://www.sau.com.au/forums/topic/34462-my-dash-lights-are-really-dark/
The right hand stalk itself only has the parking lights, low beam, high beam options. No dimmer switch on there.
Ive checked everything, pulled the whole dash apart, and nothing - no dimmer ;)
Are the red thingies which indicate which speed you're goin at, rpm, etc, meant to light up ?
Coz mine dont come on AT ALL (i dont think ?) Or if they do, theyre really dark
I havent checked the fuse
But then the back of the dash lights up green, albeit a very poorly illuminated green, so I dont THINK its the fuse.
Keep the ideas coming though ;)
Id probably just need to find the right wire for the power/illumination to the dash, and rewire it with a different impedance ?
Although I really dont wanna do that in case i f u k things up
Cheers
the dimmer in R33 is fitted on compliance. if you don't have one, the compliancer must be a bit dodgy. check the bulbs behind the dash (need to take it apart) could be one of those aftermarket bulbs with coloured bulbs or even coloured rubber sleeves on.
i always thought that they came standard on 33's well 95 and upwards anyways.
and the dimmer switch thingy should be on the left hand side under the wiper stick right next to 3 small rectangular holes used for climate control not the right. well mine is anways.;):D
I think i'll just leave it at - my compliancer is dodgy :headspin:
No dimmer switch anywhere to be found. Trust me on this one.
rs73 - I noticed that the bulbs had green 'condoms' over them. When the dash lights up, its dark green. What colour is it meant to be normally ?
Thanks for all the help so far guys ;)
Tom
In mine it has a blue 'condoms' which makes the lights turn a bit towards white when it's on.... that's a standard one. I've seen someone fitted with a painted one. Depends what paint, sometimes it's so bad that it didn't transmit enough light. the stock rubber condoms will be transparent enough so you can see the dials properly. You can try taking them off and see if it's not too bright or too yellow for you.
Yes. There's various bulbs behind the speedo face that's been positioned on "strategic" location, so that it can illuminate evenly even the needles as well. The needles are like transparent plastic that will somewhat "glow" when being backlighted. You might find yours do when you take that green 'condoms' off....
Ok what you need to do is go down to Supercrap autos or Autobarn and buy some 5watt wedge type globes. They are also known as parker globes. The standard ones are dim at 3.8 watts.
Take your dash cluster out and replace the bulbs with the 5 watt types. Make sure you do use the blue covers on them as it makes the light more "white" as opposed to orangy yellow crap the wedge bulbs emit.
There are some brands of whiter brighter globes available like Phillips blue vision parkers but I dont know where to buy these.
If this doesnt help there is a fault somewhere.
All fixed
I havent checked to see the colour of the globes - they look a bit yellowish.
But theres definitely light illuminating the dials, which is all I really need
If I get bored of this ill either get covers for the globes or go EL
Cheers guys
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
