  • Replies 113
well done! yeah I have tried and failed to flare one before. it's not easy but I can see it could be made to work. solid lines are the best way for as much length as you can use them for so it's a good idea. they are not porous so no smell and much cheaper than running meters of telfon line with stainless braid.
diff mount looks interesting too.
Cause it's a shitter 31 :)
jks nick
31 diff housing is a lot stronger than later model shortnose housings :P
gonna look into using hicas lines soon, probs gonna need twin 044s for e85 or e42.5. anyone tried simply putting some welds onto the end of the hicas lines and then clamping a hose onto it? like with cooler pipes
^^ in regards to the % duty on 1000's I sailed past 50 % duty of my ID 2000's VERY early on into the tuning process.... I didnt take much notice of what the Duty was at the end of it but personally I would be putting in the 2000's in.
What fuel pressure did you end up running...?
  • 3 weeks later...
They are a pain in the arse to flare but it can be done - there's no way you will get a proper double flare on them though.
nice setup - i wonder if there is the same clearance on the r32gtr between the diff & tank?
For anyone searching in the future, recently a GTR managed 707awkw through twin 044's on E85. Thanks NYTSKY for the headsup!!!
the boys @ powertune also had a similar result & making over 600awkw or 700awkw
I've got x2 044 w/ tomei lift pump and I'm buying some 14mm id2000's.
RB30 + new EFR8374 + E85 should be an interesting combo.
Snap....Almost exactly the same as me, I have a Nismo lifter and ID1000's (Which will prob be too small for E85)
Have you got your EFR yet? I'm still waiting for mine, I have the .92a/f T4 internal W/G one coming.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
