Item Summary: S13 RB25DET show car heavily modified s13 [smk 13]
Condition: New
Reason for Selling: time to move on
Asking Price: 19,000 ono
Delivery Methods: PickUp
Contact Info: here or 0416589889 or 0433104519
Extra Information:
S13 rb25det nearly finished project
Engine &running gear
lots of chrome
Forged Larry Perkins race pistons
Fully balanced & blue printed crank &rods
Acl race bearings big/mains
Arp rod bolts
Full reconditioned head
Rb26 gtr inlet manifold
1000cc injectors
High mounted gt3540
4" stainless dump pipe into full 3" exhaust
Orc twin plate clutch
Rb25det gear box
6x bosch external coil packs
Rb25 det power fc with commander
R200 mini spooled diff (not shimmed or welded)
Full 5 stud conversion
R32 front 4 spot brakes
1.5L stainless swirl pot
Interior
Brand new carpet
Re covered rear seat upper and lower
Modified safty 21 half cage that has been chrome plated
Recovered hood liner
Full black interior
Stealth sony cd player with column controller
5" monster tacho
Detachable steering wheel
Exterior
Full adrenalin auto styling kit
Front bar is a modified s14 bomax
Side skirts are c-west
Rear bar custom adrenalin
Full custom vented bonnet
Car has been covered in a custom pinkish red pearl
Duel blade alloy drift wing
Personal plates smk 13 (smick 13)
Wheels
Stitch rim
Fronts 18x8 235 35r 18
Rear 18x10 265 35r 18
https://www.sau.com.au/forums/topic/344658-s13-rb25det-show-car/
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
