Ok, so I've managed to get the old globe out, tweak the locking pin to fit around the HID globe, put the ignitor onto that and attach it to the ballast... but now I'm not 100% sure.
So there was a green and black cable running to the light itself, with what looks like the black one having the end cut off and changed to suit a screw in. So, I'm assuming I need cut that end off and change to suit the pin connector as per the first image. Can someone confirm for me?
Next question, the plugs that attach to the ballast, where do I need to solder these cables into?
I've scoured the net for close up pics of the back of the headlight which I'm sure will answer my question but no luck. Thanks in advance.
https://www.sau.com.au/forums/topic/344670-hid-technical-question/
Oh and give Alistair a call from Autoworx
Contact Details:
Phone: (08) 9409 2445
Fax: (08) 9409 2446
Address: 30 Automotive Dr, WANGARA W.A.
Email: sales@autoworx.com.au
http://www.autoworx.com.au/
He's does compliance on them so would know
  Chris Rogers said:
quite simple . follow the two coloured wires back to where they were cut :)
the bulb already has power.
Thanks Chris, just to confirm... so solder the green and black to the orange wires of the plug?
That was my initial plan, but the pins on the back of the ignitor psyched me out.
  • 4 months later...
Hi guys!
I finally had a chance to remove my bumper and get the head light units out......... only to find that they cut away the ignitor :(
Good thing out of this little excercise was that the HID fog light kit I have installed only had their connectors disconnected from the balast units, so connected these and whola! they worked! nice :)
I'm going to phone around locally (Perth) and find out if I can source the harness quickly or at least the ignitor piece to fix up the headlights now.
I'd like to do this soon as I am think of selling the V.... yes that's right selling the V! :( I know what you are all thinking, pointless fixing up the HID, but I just feel like doing it out of fun and to say that I finally did it :)
Ok cheers guys!
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
