Mini's fall over all the time. :rofl:
So many nice toys on MY105.
If I had my time again before I started building the Zed. AND could lose 25KG, I would have one of these.
http://www.my105.com/ListingDetails/tabid/...62/Default.aspx
http://www.my105.com/ListingDetails/tabid/...78/Default.aspx
real race cars ROCK.
This is nice to
http://www.my105.com/ListingDetails/tabid/...71/Default.aspx
Edited by Tektrader69
  • Replies 51
Mini's fall over all the time. :)
F3 cars with you losing 25kg's,,,,you still won't fit tiger,,,drivers need to be no more than 70 mate with a small arse.
News Flash,,,the Mini Cup finishes this weekend,,,wonder whats going to happen with the cars???.
NA cars are only there for the biggest revheads who have $$$ or motorsport.
NA would mostly be used in motor sport for class restrictions as a forced induction would make you play with the big boys.
but still, it would be fun building a nice NA car, but unless you have a spare 30k for a proper engien setup, id say no.
my dad built his own beetle when he was an apprentice, the old 1000cc bug, he raised compression only and used harder springs, he was pushing 140bhp with a comp ratio of 13.5:1.
a nice NA car would be a TNT King Viper.
But actually, i remember a guy a couple fo years back, who had alot of cash, back in germany on the forums , who modified his golf mk2 16v engine, he removed of his cams and replaced it with electronic lifters, rebuilt his head to run 14:1 compression and whole heap more, he managed to pull out a max of 340hp.
i guess the best NA car out there, ever to be built, are M-Power cars, if you want to go all out a e30 m3 would be the best, cant beat that. or if you have lots of cash and no worries, buy a M1 :P
im currently building a mk2 golf, with a bit of NA tuning and hoping to hit the 180-200hp
My S13 was NA when i got it.
Made about 120rwkw and was completely stripped.
It was fun, I really enjoyed driving it and pissing off the turbo boys when i posted quicker times than they did.
Totally reliable as well. No maintenance required between track days, it didn't use brake pads, it didn't cook the oil, unlike my previous skyline.
The only problem i found was on a regular track day the heros wouldn't get out of the way and i didn't have the power to get past them on the straights. I could be fair up their arse from the first to the last corner, but they'd pull 10+ car lengths on me down the straight....Not a major issue, but when you spend every second lap dropping back far enough to have a clean run it gets pretty frustrating.
Is it not back next year Neil?
No mate it's all over red rover. It was costing way to much money. Apparently some marketing nood at BMW/Mini thought it would make money,,,alas he learned a valueable lesson didn't he.
Mini's have an achelles heal,,,they run that stupid twin mass flywheel and a crappy clutch combo. Alajajian was telling me they would change or at least check the whole assembly after every race meeting. Would be a great track car with simply getting that crap sorted.
Cheers
Neil.
Cheers
Neil.
That's a shame, I really liked the Mini's as a support category. Quite good racing and pretty cool looking little things.
It will bevery interesting to see how much they come up at. I agree, I think they'd make a great track car with proven ability and already setup and raring to go.
They are moving to Suzuki Swifts for next year from what I hear, No where near as cool as the Minis lol
Ahhh yep, I saw one on my105. Hopefully still some good racing.
I'm currantly in the process of thinking of building a Datsun 510 with an NA SR20! 180kw in an under 1000kg car! should do some fair good times!??
Very cool! S15 Autech engine?
found it!
http://www.my105.com/ListingDetails/tabid/65/p/1/cid/3916/id/3383/Default.aspx
so does 45k get you just the car or entry for full season I wonder etc?
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
