I hope for some suggestions, or maybe even a referral to someone who may know wtf is going on. Short story is made a stack of mods, twins, z32s, fc, inj, pump, cams, reg, splitfires, cooler, etc. car was tuned, started perfectly, but was very disappointing in the top end.
So i had the car re-tuned by another dude with 1000cc ID's and removed the resistor pack. Tune is awesome, good on fuel, smooth idle, very linear power delivery, and decent final figure. However the startup is now crap. Cold start is quite good, also when you turn the car off and on again within 5 minutes. The problem is when i park the car for anything between 30mins to 6hrs and try start it again. It cranks forever (30+ secs), i have to pump the accelerator, and just barely starts and struggles to get up to normal idle.
To the tuner's credit, he has spent hours on it, involving an electrical engineer and can't crack it... Injectors have been flow tested, voltage tested, pump has been tested, crank signal shows on the fc controller when cranking, plus heaps of other stuff. The tuner is a champion and has probably tuned most sydney cars on this forum, so i don't think for a second it is down to his ability, has to be some weird ass quirk...
PLEASE HELP!!!
https://www.sau.com.au/forums/topic/344702-bch-wont-start/
PLEASE HELP!!!
If your having to hold your foot to the floor to get it started i think you might be using the flood control of the power FC which means you are getting to much fuel while cranking use your hand controller to trim this, I had this exact problem with my GTR and playing with the hand controller fixed it.
Goodluck.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5555658
Goodluck.
Thanks for the feedback mate. I haven't held it flat to the floor, but i have been pumping it for like 30-45sec to get it to start... I will try holding it flat and see if starts quicker, if so, than maybe it is too much fuel.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5555708
My car is the exact opposite!
Every morning or if the car has sat for a long time, its a B**th to start. I have to turn the key one shot. If i leave it in ignition till the fuel pump runs and cuts out, i have to crank it really long and depress teh gas pedal. but once it has warmed up or even after a few hours of sitting its starts like a charm. It only does this when it sits for too long like in the mornings or in the evenings after work. Anything i can do to solve this? Fuel pressure too high?
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5555843
No smoke... U guys have nailed it, on first impressions. 4 starts so far, and every one of them a winner with foot flat to the floor!
What is odd about this is that the tuner tried leaning it right out and adding heaps more fuel, both ends of the scale with no luck. He and an electrical engineer went right over the car for like 5hrs and found nothing helped. He is prob the best known tuner on this forum too, so he is definitely no rookie...
Thanks guys, i will take this idea back to him.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5557327
I had a similar problem with my R32 and turned out to be fuel pressure was too high, try adjusting ur fuel pressure regulator
if u have a fuel pressure gauge on it, if not take it to somone who can. On my car when the ignition is turned on
it is running 50psi. starts up after a single turn of the key everytime..
Hope that helps in some way
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5567640
What timing is it running at start?
The reason it is starting with some throttle is possibly die to the throttle allowing more air to enter the combustion chamber, which implies too much fuel while starting. Have you looked at any form of temperature correction in the maps (don't know about PFC, but Wolf has a seperate temp compensation map).
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5568153
  • 2 months later...
Hey guys, digging out an old thread, i forgot to check back on this...
It is running BP98 now, no E85 as yet.
I don't believe the PFC has a temp compensation map, but i could be wrong...
Trent, i will forward through my map as soon as i can download it.
https://www.sau.com.au/forums/topic/344702-bch-wont-start/#findComment-5669701
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
