Up for sale is my R34 GTT, built in March 2001. Car has done only 75000kms. I have been debating whether or not to sell my skyline, but due to our expanding family our home will not be big enough. I must sell the skyline to be able to afford a larger home and therefore sadly it must go. Car has a Brown Davis half cage with side intrusion bars which is CAMS and FIA approved.
Tuned at Status tuning and produces 291rwkw and 492nm. Number plates included in sale.
The car has extensive modifications and has a well set-up all round package.
Engine-
- Blitz turn-flow intercooler
- Splitfire coilpacks
- Blitz 525cc injectors
- Walbro fuel pump
- Z32 AFM
- Greddy swirl pot(air separator)
- Greddy oil cooler(with thermostat)
- Greddy oil filter
- Motul Nismo comp oil
- Koyorad 53mm alloy radiator
- Nismo thermostat
- Garrett 30/76 .082 with braided oil/water lines
- Custom intake pipe
- Blitz front pipe
- HKS Hi-power cat back
Management-
- Nistune ECU
- Blitz ID3 boost controller
- Blitz power meter
Gearbox-
- Redline shockproof
- Nismo twin plate clutch
Suspension and handling-
- Hicas locked
- Rear camber arms
- CST zero coilovers(10kg front/8kg rear)
Braking-
- Cross drilled and slotted DBA rotors
- Nismo R-tune front pads
- Bendix ultimate rear pads
- Motul brake fluid
Styling-
- Factory fitted Nissan bodykit
- Genuine Volk TE37 18inch rims(bronze) 8.5inch front/9.5inch rear. Fitted with Bridgestone RE55 semi slicks.
Car also comes with standard parts-
- Stock intercooler
- Stock airbox
- Stock intake pipe
- Stock radiator
- Stock rear camber arms
- Stock exhaust
- Stock suspension
- Stock injectors
- Stock AFM
- Stock coilpacks
- Hicas motor
This is a genuine and regretful sale, I am negotiable as this car must find a new home. :P
$23,500ono
Car is located in Narre Warren, VIC
All enquiries- 0411826124
Thanks, James
https://www.sau.com.au/forums/topic/344717-2001-r34-gtt/
  • 3 weeks later...
  • 4 weeks later...
  • 1 year later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
