the fuel pressure reg is to the right bolted on the end of the rail. the other two from what i understand, are fuel dampers to help smooth out pressure surging and spikes. nissan fast also lists them as dampers.
see attached,
  • 6 months later...
so what is the stock 'set' reg pressure, I read somewhere that it is 48psi with varying opinions.. So mine should be 48psi + 12psi boost??
Dont allow for boost predsure when checking at idle. When on 12psi it should rise 12 psi.
yesterday i filled up and again it did almost 20L/100kms the second time round, ridiculous economy - I would have expected it to drink less as its running lean in the mid-upper rpm band..
have you checked the fuel pressure? a dead reg can cause that
either the diaphram stops working properly and it affects pressure or they leak into the vac line and flood the motor.
i somehow managed to kill 3 regs in a matter of weeks and all 3 ran rich under vacuum and leaned right out under boost, fuel pressure just remained constant instead of rising and falling with manifold pressure.
so yer, check pressure and check the vac line for any signs of fuel
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
