the fuel pressure reg is to the right bolted on the end of the rail. the other two from what i understand, are fuel dampers to help smooth out pressure surging and spikes. nissan fast also lists them as dampers.
see attached,
  • 6 months later...
so what is the stock 'set' reg pressure, I read somewhere that it is 48psi with varying opinions.. So mine should be 48psi + 12psi boost??
Dont allow for boost predsure when checking at idle. When on 12psi it should rise 12 psi.
yesterday i filled up and again it did almost 20L/100kms the second time round, ridiculous economy - I would have expected it to drink less as its running lean in the mid-upper rpm band..
have you checked the fuel pressure? a dead reg can cause that
either the diaphram stops working properly and it affects pressure or they leak into the vac line and flood the motor.
i somehow managed to kill 3 regs in a matter of weeks and all 3 ran rich under vacuum and leaned right out under boost, fuel pressure just remained constant instead of rising and falling with manifold pressure.
so yer, check pressure and check the vac line for any signs of fuel
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
    • Yes, important point. Watch the Motive videos with Herman thickness testing the bores and deck. You do not want to push the unlucky (thin) block as hard as you can push the average block.
