Hey Guys,
I've been searching High and Low for the answer to my question..... Why don't I have any boost, even spooling until over 4000rpm or more?
I'm very new to turbo's and i've only had the car for around 2 weeks. One of my mates came for a drive with me (him being in previous skylines before) and said It just didn't have the same kick back as previous ones. Then I picked up my car after getting a front and rear wheel alignment, and the fella asked if I was running the car with minimum boost? or none at all? He said It didn't feel like any of the other ones he has been in!?!? :thumbsup:
The car has a pod filter and after market intercooler installed. Along with yellow jacket coil packs.
My questions are,
Should it have some boost even when cruising? in all gears?
Should the first stage kick in or around 2500rpm in most gears?
Should I just buy a boost tap?
Does anyone have any other ideas on what and where I should start to look? I'll post up a video of my driving it, viewing the stock gauge. Also I'll post up a picture of the vacuum hose setup near the boost solenoid (think thats the name).
Cheers in advance peoples
https://www.sau.com.au/forums/topic/344819-r33-94-gtst-nolow-boost/
This is the vacuum hose setup.... that red hose should go to the Intercooler yeh?
http://s49.photobucket.com/albums/f296/ske...-11-10_1810.mp4
Sorry for the shit video guys.
Edited by skeg_man
Trace that vac line back, it should attach to the back of the intake plenum.
From the video you are not getting boost at all.
Does it sound like a diesel when the bonnet is open? Open the bonnet, rev it up and down
you should hear a nice intake and exhaust note. There shouldn't be any roughnes. If there is, maybe
mani gasket or turbo to mani.
Alternatively, take the cat off and see if there are bits of wheel in there. Though, there would normally be a grinding /
strange sound from the turbo if that was the case.
Thanks for the input guys. Im thinking there is a vacuum line prob too. The turbo seems fine. No crunching sounds or grinds. I'll have to unbolt the exhaust and check it out. When I changed over the intake pipe, the turbine in there looked all good. Alright guys, i'll suss it out over the w/e.
The red line leading into the charcoal filter thing.... that should be into the intercooler yeh?
Does you car blow black smoke and stall/run like shit at idle?
Also check your wastegate actuator, it's that rod thing on the side of the turbo's hot side, check the rid hasn't popped off or anything.
Car doesn't blow any smoke at all and idles great. I checked out the actuator and the"rod thing" hasn't come off or anything. The actuator looks a little tired looking tho. I'm gonna get a replacement tomoz I think.
I contacted the guy that I bought the car off and he basically said that it might need a reco. Bit suss if you ask me.
Can someone confirm with me;
1. Boost should be present just driving around normal? 3psi or so? not just at WOT?
2. The red vacuum line I've posted a pic of should be fine there? or should I plumb back into the intercooler?
Cheers
Watching the video, I did not see positive boost once, only atmospheric pressure afew times... If the gauge is true, then what you have right there is a naturally aspirated rb25det, in my opinion the turbo has lost a wheel (I'm not good with R33s, I believe they have a ceramic wheel with a nylon or was it plastic compressor wheel?)
Check ur catalytic converter isnt melted. Then take the line off the wastegate and go for a carefull drive. This should make boost extremely quickly and unlimited boost so only gIve it a really short boost to see if its quicker and there is a fault with ur wastegate vacuum setup.
But
check the cat 1st. Might be melted
its probably just a vac line unplugged or not setup properly
before you go undoing all th exhausts and crap like that check the basic vac lines
find another R33 gtst near you and check how theirs is setup
Well looks like I found the problem maybe..... there must be a leak in the stock gauge line? I just finished installing a DEFI boost gauge and that is reading PSI no worries. The boost seem to be a very smooth incline, not sudden and I think thats what has been throwing me off. The boost +psi reading comes on fast when flooring it. Also much so now after doing the "stock solenoid" DIY.
Can anyone Direct me to the stock gauge vacuum line? I would like to replace it if possible.
I want to say thanks to everyone thats helped me out. Awesome forum to be apart of. :)
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
