Approx 190rwkw?!?!?!?!?!?!?!?!?!?
Man chuck the engine!
My RB20 makes 160rwkw with just 1bar boost zorst and POD why would i spend another $1-$3000 to get a 2535?????
Should be at least makin 220rwkw with that kinda boost, AT LEAST!
But i'm headin off the beaten track and goin Apexi Turbo just as good flows the same HP as a 2540R but comes on boost @ 3000rpm in a RB20
Comes with head gasket, braided lines etc everything u need to under $4000 BRAND NEW :)
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-690992
and which apexi turbo kit would that be??
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-691041
my friend with an R32 GTS-T made 227rwkw on the same dyno with a Garrett GT25 (400hp core) and this thing halls ass compared to some other GTS' i've seen.
if it's for a RB25, you'd want atleast a GT2540 which can make 250fwkw on 1bar.
http://www.hks-power.co.jp/products/turbo/...c_gt/ac_gt.html
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-691363
have you actually seen this turbo make this power on an RB25? what was the boost curve like?
not bad as its similar power to the HKS2835, and only a tad less than my 3037S 56T does at 1 bar. I would love to see a dyno for it, as I have never heard anyone describe the HKS 2540 as anything but laggy - so it would be good to see that rumour put to rest.
Its also interesting that a 2535 makes less power than a 2530 - which will put down around 230rwkw at 1.2bar.
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-691738
Just had a lookat the link you posted RS500, obviously your friend had a few problems with his 2535 turbo setup, as it is rated only just lower than the 2540 by 10kw at 1bar, BUT the mid range and bottom end is a fair bit stronger.
By comparison as the 2530 makes around 230 rwkw at 1.2bar, you should be expecting around 240rwkw at 1.2bar from the 2535.
the guy who only made 190 at 1.7 bar obviously had huge problems.
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-691751
steve,
lets not start this again.
if you read my post properly, you would've seen that i mentioned 250fwkw (flywheel kw) and not rwkw.
no i haven't seen one of these on an RB25, and what i have mentioned is what is advertised by HKS themselves.
also, i believe the GT2540 might be laggy in a twin configuration on an RB26, but i'm sure they're quite good as a single on an RB25.
check the link that i provided for the power curve, it's just as peaky b/w 3000 - 4000rpm (only more powerful) as the 2530 on the RB20.
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-691913
Yep, I have seen the link, sorry your fwkw confused me a bit, as I am used to either hp, bhp, rwhw, awhp - and havent seen that expression before.
I did have a look at that link, and noticed the 2535 has more down low, but sacrifices 13 hp up top.
Sorry if it offends, but I have seen a less than glowing report on one of these turbos (2540) on a SR20 in Zoom or HPI (cant remeber which). I would really love to see if the guys who set it up got it all wrong or not, but until I see a dyno, or hear a report from someone who owned one, why should I believe otherwise? Also, as you mention, the 2540 has a really poor rap from gtr owners.
You say lets not start this again, but you quote very poor figures for a GT2535, then go on to say you want at least a 2540, which I think is unfair if you havent seen a 2540 in action AND how do you know what trbs wants in a turbo, all he asks is 'are these any good' Your words here appear to be that of a salesman, not someone wanting to help someone assess the suitability of a specific turbo he asks about.
I think this is abit misleading, as you havent actually seen how this turbo goes on an RB 25, nor have you seen how a 2535 goes. The post about the 2535 on RB20 only shows that the info you provided is not really appropriate, as the website quotes the power at only just under a 2540.
I have seen dynos for a 2530 on RB25, which is smaller again than a 2535. and they go quite well, esp if someone is looking for an upgrade that provides a good midrange with reasonable top end (230rwkw at 1.2bar). By comparison, the 2535 has better bottom end and better top end.
Its nice of you to try and sell your mates turbo, but I believe your posts are somewhat miss leading, as you are not presenting the facts you have in an unbiased manner - this would be somewhat confusing for someone who is looking for info on a turbo.
trbs - I am sorry if I have added any confusion, but I would just like to suggest you make as sure as possible any information you see on here is as valid as possible before you make a decision. A turbo costs alot of money and the right turbo for you will be different to what someone else may want.
From the graphs on the HKS site, the 2535 will deliver a better power band for the street, where you spend more time at between 2-4000rpm than you do at 6-7000rpm. I have been in an rb2530 powered RB20 Cefiro, and it was an awesome setup. Sly33 has a 2530 in an R33, and he loves it. By comparison, the 2540 appears more laggy than either - the top end gains appear only marginal.
RS500 good luck selling the turbo for your mate.
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-691944
Steve,
firstly, i am not a salesman and never have been. If i can help someone out with some info that i know of, i will share that with them.
yes, i haven't had first hand experience with the GT2540 on a RB25 but I commented on the GT2540 simply for the fact that 'In my opinion I' believe it is better suited to the RB25 based on the information and data/specs which i have seen.
Trbs didn't specify his requirements/application for the turbo so i don't know what he wants from it, therefore, i comment on what i would prefer on that engine fomr the info which i read form the manufacturers website.
This information obtained by the manufacturer's website is what i use and should be used by all customers as to draw their own conclusions on what the HKS turbo's are capable of and then to make their own decision on what to buy.
If u have noticed in many of my posts in the past, i always try to provide specs, websites, etc (which you have referred to also) so that people (out there) can take my comments and use the data to understand more about the topic and to be able to make their own decision so don't go thinking you're some authoritive figure on turbo matching.
i do believe that the GT2540 has been found to be laggy in a twin configuration on a RB26DETT, but i believe it is quite well suited to the RB25 as a single turbo, given the larger engine capacity, it wouldn't be laggy at all.
My comment regarding the GT2535 on the RB20 was based on what i saw on my friend's dyno, so given that info, it has left a sour impression on me. Maybe the car had problems in the setup/tune which is why it didn't make the power u state, but at the same time, that's what it made, so that's what i told.
also, your claim (even though inconsistent - last time it was a RB20) that a GT2530 can make 230rwkw on an RB25 @ 1.2bar is only as valid as my one, as you could be telling figures from a high reading dyno, therefore, we cannot take these comparisons into consideration.
That's a pretty hard comparison when your friend is running a RB25 which is 500cc larger than the RB20 that i mentioned.
Trbs,
my apologies about this, good luck with your decision and hopefully you can use the info in this forum to help u learn more about turbo sizing and specs so that u can understand and know exactly what u need for what u want out of your car.
cheers.
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-692333
It's OK Steve, I'll finish, rather than start. I have tried 2540's on an SR20, on an RB20 on an RB25 and even a pair on an RB26. I have yet to find an standard or highly modified engine that suites them. I think they are a grossly mismatched turbo between compressor and turbine (ie; either the turbine is too small or the compressor is too big).
I have at least a dozen dyno graphs to support my views, when someone comes up with one the proves me wrong, then I will apologise to HKS. I have had this out there for over 2 years and no one has even come close.
That's it, next ..............
https://www.sau.com.au/forums/topic/34482-hks-gt2535-turbo/#findComment-692339
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
