Just need to know what the phyiscal/visual difference's are between the gt2860 -5, -7, -9, -10 etc.....
Some of you missed the etc lol
obviously on the GTR specific 5,7,9,10s they look identical yet gt2860 can mean other turbos too, IE gt2860rs which is completely different to look at.
Just make sure you buy the right one to suit your application, we are only assuming you want this for a GTR as you have not stated in your OP.
Thanks,
https://www.sau.com.au/forums/topic/344841-garrett-gt2860r/#findComment-5557916
Thanks,
Yeah just seeing if they had any visual difference's. All your help has been great!
https://www.sau.com.au/forums/topic/344841-garrett-gt2860r/#findComment-5557941
the part number is on the ID tag that it riveted to the CHRA.
Also if you measure the compressor inducer that will tell you what model you have; With the exception of -9 and -5 which have the same inducer but different exducers.
-7: 44.5mm
-9: 47.2mm (59.4mm Exducer)
-5: 47.2mm (60.0mm Exducer)
-10: 51.2mm
https://www.sau.com.au/forums/topic/344841-garrett-gt2860r/#findComment-5558027
Actually you need to check the compressor housing size and A/R ratio . I think the GTR style GT2860R turbos can have either a T3 or T04B sized compressor housing depending on which compressor wheel it has .
I'm not 100% sure without looking but I think the ones that are 0.60 A/R are T04B sized internally where the 0.4x A/R ones are T3 sized internally .
If you could get the comp housings off the diameter of its backing plate at the diffuser section (the step outwards from the comp wheels exducer tips) would give it away .
Also I seem to remember OE GTR turbos having a turbine housing A/R size smaller than some of the RB26 style GT2860R turbos , I think OE and some of the more responsive 2860R's had 0.48 A/R T housings and the higher performance ones 0.64 A/R T housings .
Most would know that GTR turbos use a more compact turbine housing outline that single turbo versions and the comp covers have the two bolt in and out flanges plus the two eyes at the bottom to mount the fluid junction gadgets .
Cheers A .
https://www.sau.com.au/forums/topic/344841-garrett-gt2860r/#findComment-5559437
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
