Hey guys ive alot of skyline parts that i wanna clear out, very cheap prices, i have a lot of parts so ive tried to list as much as i can, but if there is something you need that is not listed here just pm me or call me on 0422 868 703.
* Complete rb25det engine with loom and ecu $1500 ono
* Turbo Manual gearbox $1300 ono
* S1 turbo, never been boosted $400 ono
* s13,s14,s15,180, front and rear brakes and hubs conversion $800, will seperate if needed
* 2x diffs $250 each
*set of 4 stock r33 wheels $250, another set painted black $200
* drivers side quater panel $60
* lh and rh complete doors $70 each
* Complete s1 interior, ask me what you need
* Front reo $120
* apexi pod filter $50 as new
*afm $50
*2x lh electric window motors complete with regs
* Dash surround $80
* 2x dash crash pad in excellent condition $100
* series 1 complete seats front and rear $200
* Manual turbo ecu $120
* heater core $60
* flywheel $100
* factory clutch $80
* tailshaft $50
* 2x r32 gtr wheels $80
* 2x bootlid carpet $30
* 2x antennas $40
* all dash parts, message me what you need
* dash cluster $70
* fuel tank $80
* rb25det bottom end $400 ono
* 3.5" mild steel exhaust $350 ono
* rear bumper $80
* door trims $40
* stock springs and suspension $200
* radiator $100
* hicas unit $70
and more just message me what you need and should be able to help you. call or message me on 0422 868 703
thanks
* Front reo $120
*afm $50
* Dash surround $80
* heater core $60
* flywheel $100
* tailshaft $50
* 2x antennas $40
* dash cluster $70
* fuel tank $80
* rear bumper $80
* door trims $40
* radiator $100
* hicas unit $70
thanks
Hey mate,
the arm rest on drivers side is worn, how much for the trimming?
two sets of stockies. black set have front tryes rwc, the other set its basically just the wheels
Pick up from doncaster, melbourne man 0422 868 703 if u need anything guys
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
