R33 Parts Clearance ****very Cheap, All Must Go
Hey guys ive alot of skyline parts that i wanna clear out, very cheap prices, i have a lot of parts so ive tried to list as much as i can, but if there is something you need that is not listed here just pm me or call me on 0422 868 703.
* Complete rb25det engine with loom and ecu $1500 ono
* Turbo Manual gearbox $1300 ono
* S1 turbo, never been boosted $400 ono
* s13,s14,s15,180, front and rear brakes and hubs conversion $800, will seperate if needed
* 2x diffs $250 each
*set of 4 stock r33 wheels $250, another set painted black $200
* drivers side quater panel $60
* lh and rh complete doors $70 each
* Complete s1 interior, ask me what you need
* Front reo $120
* apexi pod filter $50 as new
*afm $50
*2x lh electric window motors complete with regs
* Dash surround $80
* 2x dash crash pad in excellent condition $100
* series 1 complete seats front and rear $200
* Manual turbo ecu $120
* heater core $60
* flywheel $100
* factory clutch $80
* tailshaft $50
* 2x r32 gtr wheels $80
* 2x bootlid carpet $30
* 2x antennas $40
* all dash parts, message me what you need
* dash cluster $70
* fuel tank $80
* rb25det bottom end $400 ono
* 3.5" mild steel exhaust $350 ono
* rear bumper $80
* door trims $40
* stock springs and suspension $200
* radiator $100
* hicas unit $70
and more just message me what you need and should be able to help you. call or message me on 0422 868 703
thanks
* Front reo $120
*afm $50
* Dash surround $80
* heater core $60
* flywheel $100
* tailshaft $50
* 2x antennas $40
* dash cluster $70
* fuel tank $80
* rear bumper $80
* door trims $40
* radiator $100
* hicas unit $70
thanks
Hey mate,
the arm rest on drivers side is worn, how much for the trimming?
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
