Has anyone fitted an LSD on this model car .. can we use complete diff from a different car that just bolt in .. open diff is sucks
3.3 from a auto 350z is probably what i will end up using think they are lsd.
Taller so might get better mileage aswell.
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5558340
Hi Austin, Once you have done this , please post the results and are you sure that the 350z diff housing & mounting is the same as the gt-8 ?
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5559328
youll need to have your speedo re-calibrated if you do this
Im not overly concerned about that.... i own a radar detector and cruise around at 130kph everywhere anyway.
Also my car is running 265/35/18 on the rear this is probably like nearly 30mm under size diameter wize compared to stock. I havent looked at the calculations..... could be intresting.
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5560690
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5560692
The factory LSDs (viscous) are not very good anyway. Probably an improvement over a truely open diff, but i'm not sure if its worth your time and effort.
You might as well grab something a bit more serious.
On that note, I have a second hand 2-way (centre only) kicking around somewhere if anyone wants it. To suit 6 speed manual. Not sure if it can be adapted to the auto or not. $400 posted. Not very street friendly but absolutely transformed the car.
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5560766
I have a nismo rear 2 way nismo centre and nismo 1.5way in my PULSAR GTIR no way in hell am i putting one of those noisy clunky pos in my GT8 the stock viscous is perfectly fine for my driving with this car.
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5560786
I personally do not think that there is much difference between the stock open diff and the stock viscous diff. The latter is obviously preferrable but I wouldn't bother going to the effort of fitting one.
Anyhow. I agree that a nismo unit (or similar) isnt for everyone, hence why I had mine removed.
The carbonetics 1.5 way seems nice. Friendly enough for the street. Supposedly you need to drop the oil every 5,000 kms though.
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5560868
I ordered a Quaife diff close to 2 months ago, should be here soonish
Diff of choice if you want a proper LSD that wont clunk/chatter for your daily drive
also it wont ware out because quaife diffs dont use clutch plates
https://www.sau.com.au/forums/topic/344870-v35-gt-8-lsd/#findComment-5561162
  • 5 months later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
