[sydney] R33 Gtst Series 2 Parts Fs
  • 3 weeks later...
  • 1 month later...
do you have any of these still left?
- apexi power intake
- front strut brace
- boot trim that covers the battery
- the screw that holds the coolant bottle in from the top
Gone
Gone
Gone
Maybe, I sold the coolant bottle but the screw might be in the car. Can check tomorrow.
Hey man,
They were genuine parts and they fit pretty well but unfortunately they too are sold :( So is the wheel.
Ill give a run down of whats left:
Rear tail lights really good condition
Bootlid in alright condition has holes for genuine GTR bonnet
Driver side door bar the window control thing
a JVC headunit
Most parts under the car and suspension related bar the shocks and springs lol
Some interior
Passenger side air bag
The engine, but I may be keeping this.
ABS pump
Fuel tank
Other little things
in that case could you send the left rear tail light to vic for $30?
and by the way do you know if there is a difference between the s1 and s2 tailights?
cheers
Ive got it but I cant send it for $30... Its pretty bulky to fit in a box, I'd be practically giving it away... $60 shipped to melbourne. They are in mint condition and they have both been re-gooed so they wont leak anymore like others do.
rear 1/4 door trims?
Driver side yes, passenger side no.
$15 pickup.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
