TO THE TOP
Gearbox mount sold, AC fan sold, window control switch sold
DBA rotors no longer for sale.
ALOT OF SHIT STILL HERE, OFFERS PEOPLE. SOMEONE TAKE THE GEARBOX
IVE GOT A HEALTHY EXEDY HEAVY DUTY CLUTCH. IVE STILL GOT A MOTOR!
I dont really understand. Are my prices too high? People ask for things, I pm them then never heard a word.
Please only PM me if you're interested. If my prices are too high, make me an offer.
Turbo SOLD
Dump SOLD
Cat SOLD
Brake calipers PENDING PAYMENT
Rest of the gear still here! This exhaust sounds awesome people! Someone buy it!
Still have a F***load of parts left! Practically a whole car.
Gearbox $1200 with Exedy HD clutch and new urethane mounts
PowerFC ECU $1000
BuddyClub Lightweight P1 Shadow Chrome with Kuhmo Ku31 17" $1500!!!
Apexi Power Intake Filter thing $35!!
Washer Fluid Bottle $20
Radiator Fluid Bottle $20
Catch Can $30
Standard Coil Packs loom thing with coil packs and mount thing $160!!!
Grex Gearknob to suit R33 and others maybe? $30
Cluster showing 119xxxkm $130!!
GTR pods $50 for both!
HFM Adjustable Castor Rods? I cant remember which part it is lol but the standard part mounts the LCA to the chassis and has the bushing which leaks silicone shit. These new ones are steel and adjustable and have a butterfly bush or what ever its called! $130!!!!!!
Perfectly Working AC system $750 for the package! Heater core is f**ked though lol. Will split AC parts if people take stuff!
Hi what condition is the gearbox in how many kms has it done any noises or metal fragments in the oil or on the magnetic drain plug e.t.c.
I can be contacted on 0244435198 or at [email protected]
thanks Sam..
Turbo SOLD
Dump SOLD
Cat SOLD
PowerFC ECU $1000
Catch Can $30
How much for the radiator fluid bottle with postage to canberra?? :)
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
