dears, i am facing a 4WD problem in my R33 V-spec, 4WD, A-LSD and ABS lightes turn on when start the car directly, please check the videos below:
the codes video
light up 4 times slowly then 3 time slowly, or 3 times slowly then 4 times, i dont know how to calculate it.
so need your help if any body know about it
thansk
https://www.sau.com.au/forums/topic/344900-r33-gt-r-4wd-problem/
get it on a consult and check the tps voltage. needs to be a certain voltage at idle and 5v at wot. search the forums for this issue, ive had it myself. same code, came up as a wheel speed sensor the 2nd time round, both were pointing to a faulty tps.
thanks for your reply, i will check the TPS voltage and will clean all wheels sensor today, hope to repair it,
i already changed the 4WD computers in the trunk and changed the G sensor but nothing happened, i will confirm back.
thanks again
