Consult is reporting my timing as 5° BTDC at ~800rpm on warm idle, FSM states idle should be 15° BTDC at 650rpm.
Would this affect timing over the whole rev range, and overall power? If I fix the idle so it's at 650rpm and the timing is still not correct, do I just adjust the CAS until it is back in specification?
My 33 is pretty low on power, 150rwkw on 12psi so slowly going over everything.
https://www.sau.com.au/forums/topic/344913-timing-question/
if car is idling higher than target rpm then the lower reported timing is likely the ECU trying to lower the timing to reduce rpm.
try turning idle screw down, and maybe once the ECU is 'happy', timing goes back up to normal.
the ecu's reported timing is assuming the timing is correctly set with a timing light, it has no way to know actual timing, so changing the cas will not change what the ECU is reporting, cause its an 'output' value only.
https://www.sau.com.au/forums/topic/344913-timing-question/#findComment-5559364
Thanks NewKleer
I got hold of a timing light, and confirmed the idle timing was at 5. I turned the cas and managed to get this up to around 10-12 as the timing seemed to be jumping around a lot, the ecu then reported 5-7 at idle and the car drove much smoother and puled harder.
As the cas is now turned as far as it will go and I'm still not at 15, I'm thinking of trying another one to see if my cas is faulty.
https://www.sau.com.au/forums/topic/344913-timing-question/#findComment-5569075
pretty sure that adjusting the CAS will not show a timing change in the ecu as the ecu purely uses the CAS as a reference point. when the timing is set at 15 degrees and the ecu says 15 degrees then it will be 15 degrees. if you retard the timing via the CAS to 10 degrees with a timing light, the ecu will still say 15 degrees however it will actually be 10 degrees, but ecu won' know it.
have you been using the consult program to put the car into base idle/timing mode before adjusting the timing? if not then the ecu may be altering the timing and you may actually have it set at 20 degrees or higher. you need to make sure the car is in base ilde mode (best to have the car to be up to operating temp) and then adjust the idle to the desired rpm and then check the timing.
https://www.sau.com.au/forums/topic/344913-timing-question/#findComment-5570028
Thanks NewKleer
your doing it wrong and potentially dangerously.
set it back where it was, as that was correct and wind the idle screw down as newkleer said
https://www.sau.com.au/forums/topic/344913-timing-question/#findComment-5570194
yes you should only adjust the cas when in 'base idle/timing mode' via consult (or similar manual method) which would lock timing at its static value. that consult said 5 deg (should be 15?) means it wasnt in this mode.
the consult output for timing is the ecu's calculated value assuming timing is set correctly with a timing light - the ECU has no way of 'reading' the timing, otherwise it wouldnt allow you to adjust it via the cas...
https://www.sau.com.au/forums/topic/344913-timing-question/#findComment-5570352
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
