89 R32 GTR
i have spent well over 15K in the past few months on this car , and it is now up for sale is more of EOI
then a sale , as if it doesn't sell i am not that fazed.
have owned this car for 5 months and spent more time in autosport engineering
then at mine(lol i just keep doing more to it)
rb26 rebuild at most 15k ago
cp forged pistons
n1 oil pump
metal head gasket
to4z at most 15,000kms old
ETM exhaust manifold
trail waste gate
700cc biltz injectors fully cleaned and spray checked 1000km ago
Bosch 023 intank pump maxed out
HKS hard intercooler piping kit
greddy steal intake pipe
twin Z32 AFM's
HKS mushroom pods
custom air box
carbon bonnet
R33 GTR seats
boost gauge
Blitz ebc 1000kms old
PFC with hand controller
HKS cat back
external gate as a screamer
WORK Vssf rims
Spitfire coli packs 1000kms old
greddy oil catch can
HKS coli overs
All brand new silicone hose kit under intake manifold
full engineered with papers
all oils and water flushed less then a 1000kms ago (motor , gear box , diffs , trnasefer case , raditor)
new tires less then a 1000kms ago
after market steering wheel
aftermarket very heavy duty clutch
cd/mp3 player
portable more i have missed
have receipts of a lot of work
it made 316rwkw on unigroup engineering on 16PSI witch is VERY
low boost on this turbo , and was caped at this as the fuel pump couldn't push any more fuel, add a surge system
and some more boost and power will go up a lot more, the body is not a bad condition could do with a few touch
ups but over all not a bad at all specially for its age. all electrics work BUT the clock? no idea why
Price is 24,000 ONO
phone number 0411838610
their will be no one elsa then me driving the car unless you have a deposit on hand AND PROOF you can actually afford the car.
the car is located in NSW Newcastle
https://www.sau.com.au/forums/topic/344916-r32-gtr/
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
