Umm possibly not. You really need to give a better description of what went on. did you just come out to drive it this morning and it wouldn't go? were you flogging it last nite and it made a bang and would't go? could possibly be a drive shaft/ tailshaft or input shaft from the gear box all of which would have made a bang if they broke.
tell us more dude, also from sig I'm guessing a GTR?
ok this is what happen i try to test my clutch if it is slipping so i start on third gear and revved and i heard nothing and the car just revs and dont go anywhere so i pulled over to the side and put in gear and leave the clutch and it didnt stall so i try every gear and it didnt stall so i assume its not even in gear and it is the gtr
hmm so it was driving fine before you stopped (at a set of lights) ?? and put it in third to take off? and it is a GTR?? more details dude. and by the way you should put it in 5th and let the clutch out to see if it is slipping. but really a slipping clutch on a car with any decent amount will easily be felt when it comes onto boost.
Thinking about it... is the clutch fluid full? did you get under the car and see if there is any fluid leaking? is there any kind of a smell? when the car is ideling put the clutch in and out, maybe in the garage or in a confined space so you can hear any different noises it makes while you do this.
It does sound like the clutch to me, This also happened to me in my old car. But i might be wrong.. Dont take my word for it and go changing your clutch :Oops: .
I feel for you dude.. Just picked up your car didnt you? Black smoke coming out and now having more problems... :goddam:
which part is clutch fluid and yeh it had smeel since i bought it and there is no leakage as i can see it but i am getting it towed tommorrow since i need it but i just want to determined the probs first i guess thats what happen if you buy those 89 gtrs hope nothing else arise
do u have a clutch pedal at all? Ur cable could be broken? The throwout bearing used to get stuck with my old brass button when i got the car and i would have to stop on the side of the road. Way i would overcome it was, turn the car off put it in gear and start the car in gear so it jumps abit but then change gears once with no clutch and it went clunk and pops back into place, doesnt sound like ur prob but hey u never know. My clutch lasted for ages one it started slipping, so i find it odd to have it just fail without warning on u, maybe there is more to it. good luck in finding the prob
only thing i can thing that it could be, that u blown the synchromeshing or the actual linkage to the gearbox, and no it doesnt sount like a clutch, cos if it was clutch the motor, you will hear it rev up and spool up but not move fast at all, so therefore im pretty sure its not the clutch but the box, u might wanna check that to, it happened to me in the laser, (yeah i know a laser is diff to a skyline, but after a 1 grand super single clutch, i knew it wasnt the clutch, and i blew the synchromeshing)
One of two things:
1. Broke the centre out of the clutch's driven plate.
2. Broke the input shaft to the gearbox.
Junkie, you still haven't made it very clear what went on prior to you getting no drive from the gearbox. If you were caning it, then we need to know stuff like that before we can make a diagnosis. It's like going to the doctor and simply saying "I feel crook in the guts". Doc can't very well diagnose what is causing it with a statement like that.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
