Hey guys...
I've seen 2 different 180's in the last 2 weeks, both must be running without BOV's...
What turbo do they use (i'm guessing it's std. as they both sounded identical) and what makes their 'flutter' sound so damn good?
I know this is one of those personal opinion things and a lot of people will say flutter is bad and sounds crap...etc.
But yeah, i like the sound of a 180's flutter...
Also, how can you get flutter without the backfiring?....
https://www.sau.com.au/forums/topic/34497-turbo-flutter-on-180sxs/
oh, ok then... thanks for that...
So, is there a way to make a gts-t (R32) flutter without stalling and backfiring?...
I know you can change the computer set-up but that's about $2K so stuff that...
other than that i can adjust my BOV right up (GFB Hybrid).... how will this go with stalling and backfiring?... anyone know?...
(and yes.. i know this sounds like a stupid thread but hey... i like flutter)... lol
hey dude, i got the stock bov on my r33 gts-t and when i put a cooler on it started fluttering pretty clearly and loud too, im putting on a hybrid bov so it flutters at low revs like below 3500 and then normal above those revs,
also ive never had any stalling or backfiring problems
dont worry i like the flutter too hehe
cheers...ben
lol... kool,
Yeah, I havn't put on the FMIC yet, and i'm gonna replace the intake pipe with a steel item i think... so it should sound good then?...
Yeah, my Hybrids set to about 3000RPM; never had any dramas with it there so i might up it a lil bit and see how it goes each time i adjust it... cheers.
DJ.. Im not sure you totally understand how it works.
The Flutter is made when the compressed air is forced back through the Turbo
Due to the Throttle body closing (lift of throttle) The air has to go somewhere.
A BOV negates the need for air to be forced through turbo via to methods.
1.Legal ; Venting back to the Intake before the Turbo via a line "plumbed" from after turbo to before turbo
2Illegal ; Venting to atmosphere .
Point; If you really like the "flutter" get rid of your BOV but know that it will reduce the life of your turbo.
good luck...
Andrew..
I had awesome sounding flutter on my R31 GTS-R. But if I shifted on boost and held in the clutch it would sometimes stall. I fitted a plumb back BOV and this has now stopped. I liked the flutter sound but would rather prolong turbo life no matter how little extra it might live.
I also noticed it generated boost between shifts a tad faster after it was fitted obviously because the turbs had not slowed down as much as before.
Well my mate has a 180 and the sound (flutter) is from the stock bov, he has a pod filter in the engine bay, it is just the sound of the stock BOV sounding through the filter, it will be louder on higher boost. On my car I have awersome flutter (everyone loves the sounds my car makes) this is only on low boost under about 8psi, but when I boost up i get more of a normal BOV venting sound. I have a turbosmart supersonic type 3 BOV I also have a bigger turbo so that helps becasue of increased airflow.
good luck...
Andrew..
Yep, I knew all that man... the turbo might be replaced this year so not overly concerned there...
Af far as taking the BOV off... that is what i wanted someone to say so i could ask the next question...
With no BOV (please only speak from experience, not theory)...
Do you get that crappy backfiring?
Do you get that stalling problem?
Cheers...
Cheers...
Yes
and Yes.
You'll might get similar problems with an Atmo BOV too as opposed to a Normal Plumb-back one.
This is from expiriance. But as you said, aftermarket management fixes it... but that's a few $$$
Mine flutters...even before the cooler
I have a HKS BOV and HKS POD (BOV dont go back into turbo :wave:)
Flutters before the cooler? I'd like to see that one.
The flutter has nothing to do with your I/C at all.
the stalling/backfiring problem is caused more by an atmospheric BOV than no BOV due to the engine running richer because the air it was meant to use has just been blown out, i have a full atmospheric on my 33 and i had it tuned also so that it wont stall and will never backfire, so if you have some tuning methods u can do that too
DJ: Yeah, i know that the stalling and backfiring is cause the air isn't going back past a certain sensor or something like that ( if someone want's to increase my knowledge, feel free)...
How do you mean you had a full-atmo BOV tuned?... I know with the GFB BOV's you can adjust them so they'll only go off over certain revs etc... but i still get the (very) occasional 'pop' out the exhaust... NO WHERE NEAR as bad as some cars i've heard that make a huge cracking backfire EVERY gear change.... (that'd just give me the shits to be honest)...
Cheers...
Speaking only from experience and not theory my car use to have idle issues when i had a vent to atmo turbosmart BOV (apparently it would stick open )
Now i run no BOV and there is no Idle issue's at all.
Dont know what you mean by backfire. (please elaborate)
But if there is an idle issue there is another problem..
So yeah no BOV rund fine NO issues whatsoever..
PRO_32: I've seen Silvias and a Pulsar GTiR both (i am assuming) where running straight to atmo-BOV's....
Eash time they changed gears there was a loud "crack" sound soming out the exhaust (backfiring)... i sometimes get a litlle "pop" but never anyhting like either of these... it's really loud and like cracking a whip... does that help?
If you don't know what these problems are and you're runnning NO BOV, then I imagine there won't be a problem if i do the same...?
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
