I bought a r32 gtr and always thought it was too laggy for stock turbos but after checking everything i could think of just decided thats how it was.
I bought a power fc, adjustable cam gears, boost controller and took it to a dyno tuner that was very highly recommended where he informs me that this is not normal so after a full day of him checking everything its making 200awkw on 12 psi which is apparently about right but it doesnt make full boost til after 5,500 rpm it just builds up slowly
Has anyone heard of this? cam timing has been down by the marks and the amount of teeth on the belt, no vacuum boost leaks, turbo actuators have heaps of pressure on them, i have inspected the compressor wheels on the turbos, swapped intercoolers, air filters arent restrictive, really the next thing is to inspect the exhaust wheels and the flaps to make sure they are sealing but because thats not a fun job i thought id see if anyone else has come across this problem and my tuner has never had this happen before
Standard turbos, standard manifolds (no exhaust leaks) im assuming just no brand stainless dump pipes the kind that seperate the wastegate from the exhaust and the plumb back in (which im not a fan of)
cheers
https://www.sau.com.au/forums/topic/344982-unusual-lag-problem/
Since it's a 32, it's possible you have the 32 Nismo turbos, steel wheel and the laggiest of all the garrett turbos with steel wheels. Even with them though full boost at 5500rpm, should be seeing full boost much earlier maybe about 4000rpm instead if you indeed had them.
Have another play with the inlet cam timing. My mates was doin the same thing and adjusting the inlet cam netted a much better response. About 800rpm difference.
This was with 32 nismo turbos.
His was the same 5500, now 4700rpm and makes 300kw on 19psi
well im pretty sure i didnt have any and the tuner checked too, once it gets to 12 it holds it fine? isnt it still laggy for n1s? and shouldnt it of made more power? i guess the engine could be tired
thanks for everyone input
The fact that it holds 12psi doesnt mean that its not a boost leak, the turbo/s are just working much harder to keep it at 12psi. Mine ran exactly the same boost pressure just took longer to get there for the turbos to overcome the leak. If it was a huge leak then yeah maybe it wouldnt be able to hold 12psi but a smaller leak would.
Can be hard to hear especially if its while the engine is running. I just blocked off the pipe running into the engine and made up a fitting with pvc pipe and used a hand pump to pump air into the system. Was super easy to hear where its leaking out cause there are no other noises. Cost me $20 for a hand pump and $6 for 2 pvc caps.
Might have to compression test it, kind of been putting it off because then i might have to rebuild it! makes sense harey ill give it a go, easier than taking the dump pipes off to check if the flaps are sealing which is all i could think of to do next!
cheers guys
You could also try removing the boost signal to the actuators and give it a very careful run to see if they spool earlier. Boost will keep rising so shut it down as soon as you see boost build so you dont blow the turbos. If they are truly stock turbos you'd want to make sure you didn't push it past 3000rpm. If you're at 4000rpm with still no boost then you can be certain its not a boost controller problem.
My first R32 had a "Hiclone" installed in the intake pipe making it much harder for the engine to breathe and consequently made the car feel very laggy. Once removed it behaved normally. A similar restriction somewhere from the air filters to the intake plenum would cause this problem. Your intercooler is not partially blocked? If you really wanted to get technical you could measure the pressure drop across the intake system.
ive tried another intercooler and lower piping and had the other piping off but i have never heard of a hiclone! one thing is the afms are reading around the same volatge so each turbo should be sucking the same amount of air which is swinging me towards a boostleak/restriction
taking vacuum lines off actuators didnt make any difference, i did end up having a inlet manifold gasket gone but that hasnt fixed it. replaced anything thsat looked even half dodgy (hoses etc) still no better!
thinking it has to be turbo related? funny thing is the afm reading is around the same
remove the cat wire up rest of exhaurst and take for a run around the block, it will be very loud but will remove any possible restriction in exhaurst and help rule out exhaurst, split dumps are better
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
